1977 23' Birchaven Batteries
Tom Katzenberger
795
287
63
Good day all,
I am going to install new batteries in the coach. The question I have is what is the best choice for the house battery and coach battery?
Should I go with a marine battery? I only have room for 2 batteries. I fabricated a new large stainless steel battery tray which is 19" x 20" so I
should be able to handle large batteries plus some storage. I am not very good in the area of electric and am all ears?
Thanks again all,
Tom K.
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D.
IF you only have room for one battery for the house, I guess a "marine/deep cycle" would be the best choice.
Better yet, although more complicated, convert to Lithium batteries. Jerry Work has a good tech article on GMCWS.org:
http://gmcws.org/blog/lithium-battery-presentation-gmcws-2019-fall-rally/
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Tom,
Amazon is listing a 200Ahr LiFePo4 for 800$.
This is all I know about it. It is attractive, but it will need a DC-DC charging system.
Matt and Carl,
I will go the direction of lithium for the coach and acid battery for the engine per you guys suggestion. I watched the presentation on the Lithium
and it doesn't seem too difficult.
Thank you guys for the input, again it is very much appreciated!
Take care,
Tom K.
Amazing! Prices still falling quickly. I popped last year at $1400. Now
half that. Another year and they'll be a no brainer for everyone.
bdub
http://bdub.net/SweetPeaSolar/
> Tom,
> charging system.
> Matt
> GMCES
Tom,
I'm not sure I understand your 2 battery limitation. You meant 1 starting and 1 house battery, right?
My Birchaven has the 1 starting battery behind the driver's side headlight and the 2 house batteries behind the passenger side headlight. I thought
this was Birchaven standard. What's preventing you from having 2 house batteries up front?
Richard
'77 Birchaven TZE...777;
'76 Palm Beach with 18,477 verified miles;
‘76 Edgemonte
Because Chaumière is a 73 and I have the air pump under the driver, I have three batteries in the other corner. That is a pair of GC2 (T105) and a
Grp 36 starting battery. There is also the little (aka cheap) battery back by the APU. I made the larger battery tray out of fiberglass covered
plywood years ago.
My 23' has the Ragusa 3-battery tray on the passenger side with 2 each
GC-2's for the house and 1 each Gp 27 for the chassis. Because of my
grille-to-radiator ducting and other components, the batteries must be
R&R'd thru the wheel well. Pretty easy on my service rack with a special
mod to my engine hoist:
http://www.gmcmhphotos.com/photos/g5425-battery-lift.html
For those without a lift, I suggest an unload/load ramp. That's a 1x6
board long enough to reach from the back of the battery tray to the upper
A-arm. At the tray end of the board, a piece of angle iron screwed to the
end engages the lip at the back of the tray to secure the "ramp". Works
pretty well -- IF you can lift the battery onto the ramp by hand. Then
side the batteries up & down the ramp.
By the way, for anyone who wants to make their own battery tray, here's the
template developed by John Richardson:
http://www.gmcmhphotos.com/photos/g4280-battery-tray-pattern.html
> plywood years ago.
> Matt
> GMCES
> thought this was Birchaven standard.
My Birch came with 1 house up front with the starting battery and a 2nd paralleled in a vented box under the bed in the back.
Tim Taylor
Austin TX
Philadelphia PA
76 Birchaven (SB)
76 Triumph TR6
Very nice information, I keep thinking I will have this coach up quickly, but by the time I keep making improvements it has been set back quite a bit.
> bit.
Tom,
We all fight this battle. Decide what mods you really need and put the others on a punch list. Go enjoy the coach and it will motivate you to make
the important changes first. (Says the guy that has the front of his coach apart for a repair but is planning three upgrades while it is.)
