Goodyear makes all steel radials under the G159 group with both
long-wearing standard tread and a M/S (mud and snow) tread. Load rating are
at 65 MPH.
The same LT225/75R16 tire is rated at both D and E depending on the
inflation pressure.
The single load rating for D is at 65 psi for 2,335 pounds/tire.
The same tire at 80 psi is an E rating of 2,680 pounds/tire.
Duals (same axial) are derated 8% but does not apply to GMC tandem axials
http://www.goodyear.com/nat/pclt_cat/products/g159.html
at 65 MPH.
inflation pressure.
