Paul,
I lost the magic smoke from my original Norcold. I will NOT have any more
propane refrigerators. I decided to fix what I had.
I started by purchasing a 400 watt invertors. I did get a pure sine wave
unit, not because I needed it, but because I wanted it.
Then I bought a 120 to 24 volt transformer and a $2 relay from Radio shack
with a 120 volt coil. The relay normally sends 12
volts to the inverter, but if 120 volts is available it switched to that.
The 120/24 volt transformer takes either power source and
supplies the reefer. I even whacked the old wires off the old power unit so
I could easily trace back what I had done. So far I've
never had to. The whole deal seemed too simple, so I showed my wiring
diagram to Ken Henderson and asked "What have I
dome wrong?" He said if it works and gives no problems, you're good to go.
Oh yes, the inverter has an extra outlet that I can plug my TV into when dry
camping at Camp Wal-Mart. JWID
Gary Kosier
77PB w/500Cad
Newark, Ohio
Sent: Thursday, September 22, 2016 11:24 PM
To:
Subject: Re: [GMCnet] 12 volt refrigerator
> I am interested in several aspects of this as well. We would like to do
> something about fridge in our coach. We still have the original Norcold
> 12v/120v fridge. But it no longer works on 12 volts. I do not currently
> have an inverter on the coach. For lots of reasons, I do not want a
> propane
> fridge.
> I could probably find other things to use an inverter for, but... We
> rarely dry camp. I would like to be able to have the fridge running while
> driving, and possibly for an hour or two while stopped for dinner, etc.
> For lots of reasons, I do not want a propane fridge.
> I have read several posts about people using the small ac only dorm
> refrigerators. Some posters have been more forthcoming about the type/size
> inverters they are using. Are people using true sine wave inverters more
> satisfied with their ac only fridges?
> How big an inverter do you need to start these fridges? Do you need a
> bigger inverter if you are using a MSW vs. a true sine wave inverter?
> As for me, I am considering either a 12 volt only fridge, or the apartment
> fridge with an inverter. I have pretty much decided that if I go the
> inverter route, it will only be with a true sine wave inverter. But then
> the question becomes how big is big enough? The 12 volt fridge is
> expensive
> but efficient; the true sine wave inverters are not cheap other, but may
> have more utility for other appliances.
> I have read Rob Allen's write up about the original fridge, and agree with
> most of his reasoning. One thing that has changed since he wrote that, is
> I
> see a lot more of the dorm size fridges with yellow hang tags less than
> his 262 KWh rating these days.
> Lots of questions, but mainly interested in what type inverters those who
> have ac only fridges are using?
> Thanks,
> Paul Zerkel
> '78 Eleganza II
> Salisbury IL (near Springfield)
