Hi Scott,
I took my onan out last week, Well almost out.
pulled it out just far enough to get to the bridge
rectifer. Mine wasn't putting out, so I got a
new one. bridge rectifer. $10.89 at a local
electronics store. Fired it up and it started
the AC up on high. Really kicked out the cold
air then.
Rob Teed 74 Painted Desert Lansing, Mi
Heading to Key West 3 days...
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of Adohen
> Sent: Tuesday, May 11, 1999 10:35 AM
> To: gmcmotorhome
> Subject: GMC: 0 watt Onan? Test bulb does not light.
> Hi Gmcers!
> Got the Onan to run 50' away from the coach, therefore no wires
> attached to
> the coach. I tried to check for power with the large wire
> connectors at the
> rear with a light bulb attached. These 2 wires seem to be about 4 guage.
> There are four other disconnected wires that I believe should go to the
> remote start inside the entrance door and not connected. Did I attach the
> bulb to the right terminals? I have a GMCMI prepared manual
> about the Onan,
> on page 31 at the bottom, it says "... sometimes field armature loses
> magnetism due to long storage and needs to be shocked to produce
> a DC field
> around armature." Anybody know how to do this procedure?
> Thanks
> Scott
air then.
> [mailto
> To: gmcmotorhome
> Hi Gmcers!
> attached to
> connectors at the
> about the Onan,
> a DC field
> Thanks
> Scott
