Do I have a problem?
I've got three batteries in my 1977 Royale - Starting, House and
Generator.
The Maintenance manual diagrams, however, only show two. For example, the
diagram
entitled "1977 and 1978 GMC Motorhome Living Area 12-Voly DC Electrical
System...."
show how the "cranking" battery and "Aux" battery are connected.
Part of my problem is that the House battery wire, that I
would have expected to be routed back from the front, where the battery
is located, to the converter in the rear, is not. Tracing the wire under
the MH, the Red large gage wire is tied off in the vicinity of the
generator and is terminated in a heavy ring terminal which is not
connected to anything! Two inches away there is a Red wire from the
generator battery and that is connected a stud terminal on what I
believe to be a fuse (metal block about 2" by 3/4" with two studs). The
other stud terminal is connected to a Black very large gage wire which
goes to the converter. The "fuse" is just hanging in the air with the
wires attached. So it looks like the way it is connected NOW, the
generator battery is only charged by the converter and the house battery
is only charged by the alternator. Also the Generator battery is the only
source of 12 vdc for house needs.
If I were to connect the Red house battery wire to the same stud
terminal
that the Red generator wire is connected to, then, I think, I have the two
batteries in parallel. Then both batteries would be charged by either the
alternator when the engine is running or, when stationary, by the convertor
when it gets shore power or AC from the generator. I am concerned that
this would mean that, when the engine is running, the alternator would
be charging all three batteries - is this a problem?
This would also mean that when I select BATT BOOST, all three batteries
are available for starting.
All three batteries are identical, looks as if they were bought at the
same
time about a year ago.
I just don't see a reason for someone disconnecting the House battery
wire
in the first place and am a bit apprehensive about reconnecting it.
Hope this was clear enough.
John
FMCA 231235
Generator.
diagram
System...."
terminal
same
wire
John
FMCA 231235
