The vertical "rail" (as its called in the parts book) holds the fixed half
of the window against the frame. Mine came loose, allowing the glass to
slide rearward enough to leave a 1/4" gap between the front edge of the
fixed pane and the frame. My son-in-law removed the rubber seal, moved the
glass and the rail forward to their original position, applied some butyl
sealer and replaced the seal. However, while we expected to find screws at
the top an bottom of the rail,it appeared it was only heald in place by the
sealer, no screws.
Did we miss something, or is this something I need to monitor regularly?
Its my intent to take the coach to an auto glass shop to have all the
living area sliding windows "reset" to prevent a recurrence and reduce the
liklihood of leaks. Am I on the right track?
Dave (advisor/navigator) & Dege (ALL else), '76 Royale, Santa Barbara, CA
sealer, no screws.
