Hi Emery,
Thanks,
Do You want some money? Plus some postage? If You dont want any
money then Check out my post on Long Distance Calling.
I would consider buying the new latche's but
Would be wary of the easy entry. Have You replaced the felt in the
window track. I noticed after I replaced my felt I could no longer
push on the outside glass to unlock the windows.
Thanks,
Rob Teed 74 Painted Desert
Mailing Address:
Robert Teed
4245 W. Jolly Rd Lot 269
Lansing,Mi 48911
> Rob - I think that I still have some of the original latches because I
> replaced mine with a newer style from Hehr International. You
> might want to
> consider putting the new latch. It makes the windows much easier to slide
> open. This is for the large sliders (not the two little sliders
> by the driver
> and passenger seat). Depending where you buy them you'll
> probably pay $4.00
> to 8.00 each. One thing I found is that with the new latches you
> can press in
> on the glass by the latch and easily slide it open from the
> outside. I cut
> some small dowels to fit in the track to keep it more secure.
> This is similar
> to the stick some people use at home with their sliding doors.
> If you need an original I'll give it to you. I have the latches but the
> "Keeper" on the fixed part of the slider was used with my Hehr latches.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
