WIND NOISE
thomas g. warner
1,863
Took first 450 mile trip yesterday in my first GMC motorhome and heard lots
of windnoise around the front windows. Is this normal or is there someway
to reduce it. Am I incorrect in assuming that much of it comes from the
outside mounted rearview mirrors? Is there a better and quieter outside
mirror available? Any help will be apprreciated.
I have worn window channels for sure, did not think that they would cause
this kind of noise though.Am planning on replacing them as soon as I
complete the big jobs.
>You may be getting some wind noise from the sliding windows. Mine had a
>tendency to slide open slightly and leak air. The original window locks left
>something to be desired. I solved the problem by getting quarter inch or five
>eighths wooden dowel sticks and cutting to the right length to wedge between
>the bottom of the window and the front. I found I needed to put a screw in on
>the other end for it to wedge against. No air leaks now. You may also have
>worn window channels.
