You never use a flat surface not on an Aluminum wheel as it cuts into
the hole on the wheel has a tapered hole, then you use a tapered nut.
> Larry,
> If they are stock steel wheel lug nuts the ION lug nut wrench probably
> will not fit. I just bought a set of ION's from JimK (Love them) but the lug
> nuts are a smaller size than my old 16.5 standard wheel lug nuts. I called
> Nick to confirm the recommended torque on the ION lug nuts and it is 145
> foot/lbs. I always needed a 3 foot cheeter bar to break loose the steel
> wheel lug nuts, but my torque wrench is enough for the ION's. HTH
> Doug
> Douglas & Virginia Smith
> dsmithy18 at gmail
> Lincoln Nebraska
> ’73 “Canyonlands” since ‘95: "Wanabizo";
> Quadrabag/6 wheel disks/3:70 final/Paterson QuadraJet/Thorley’s/Alloy
> wheels(finally!)/Sundry other
http://www.gmcrvparts.com
