Wheel bearings
thomas g. warner
1,863
Henry each bearing and race sold as suitable for the GMC should be etch
marked with a number. For example one of my new timken sets has on the inner
race 1205 etched, and on the outer race the same number. The spacer has
etched in the outer edge .0095, which signifies that the bearing set has
.0095 of axial clearance when installed on the hub. Hope this helps.
>>Hi Henry,
>> I'm going to pull the rotors off, get them turned
>> replace the pads. Check the wheel bearings.
>If you check them you may want to replace them. I my conversations with the
>Timkin engineers it's become pretty clear that fingerprints and dirt can
>seriously decrease the bearing life. So, I replace the bearings whenver
>they "need" to be inspected. I know that I may be throwing a few $$$ out
>the window, but that's better than a breakdown.
>If you haven't already done a front bearing job, you should probably
>consider it unless you have the prior owner's records and KNOW that the
>folks doing the work did it right.
>> Thats what I'm going to do.I have an autozone
>> nearby. What parts might I need to do this job?
>You'll need the bearing tools. I've chosen to buy bearings from Cinnabar in
>the theory that they are most likely to getr the right tolerance bearings.
>Timken ships them a special selection from their standard bearings.
>Unfortunately they keep the same bearing number wiht no additional
>designation. So ... you can't tell from the box whether or not you have the
>right bearings.
>Henry
>Henry Davis Consulting, Inc / new product consulting
>PO Box 1270 / product readiness reviews
>Soquel, Ca 95073 / IP reviews
>ph: (831) 462-5199 / full service marketing
>fax: (831) 462-5198
>http://www.henry-davis.com/ http://www.henry-davis.com
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
I didn't look for an etch number - just the outside of the box. Could you
check your box for a P/N? Wes at Cinnabar was the one who told me that
Timken didn't create a new P/N for the .0095 axial clearance sets. So, the
boxes are marked with the plain P/N. Maybe there's another myth to kill here.
Henry
fax: (831) 462-5198
Henry mine did not even come in a box, rather a plastic bag within a plastic
bag, each part of the bearing wrapped in a oil impregnated brown paper.
Information on one of the bearings:
-Information on the inner race in order: Timken,.1209 (etched by
hand),LM104949E,+,USA AL.
- Information on outer race in order: TIMKEN-LM104911, USA, CD,
etched by hand 1205.
-Information on spacer in order: LM104911EA, .0095(etched by hand),
.1205 (etched by hand)
Hope this helps.
>Henry
>fax: (831) 462-5198
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
FWIW, Cinnabar's price for the bearing set is now $94, plus shipping.
Personally, even if that were $30 more than local, it's a small amount to
pay for peace of mind.
With the right bearings and using the right tools and grease, we'll put
this subject back on the "just do the maintenance and don't worry about it"
list.
Suspension and brakes are primary, and the rest is secondary (no matter how
fast or smoothly it goes, you've GOT to be able to steer and stop it).
___________
Dave (& Dege), '76 Royale /_][__] [_] | "SR JAMES"
Santa Barbara, CA *-0------OO--* (our hobby)
