Clark,
Some will say that Bilsteins are better, but I have had 3 fail on the rear of my coach and it is now all KYB. Those are the only two manufacturers (I
believe) that still make the reverse damping that is needed for the rear four.
Back when I was racing small cars, Bilstein were the only ones that would A-Last, B-Work.
As you might guess, I am no longer impressed. Of the three that leaked, two just leaked and the third started leaking when I jacked up the rear and
even with no pressure on the airspring. When they leak fluid, they have alos leaked some of the gas charge.
