We are in
gene
2,215
Hi Arch
Just got back from the ALBQ rally., I had to leave early.
The engine guy talking there said he would not recommend doing just a top
end job. He said, you put in all that money and then something goes wrong
with the bottom and you will have to do it all over again since you would
not put old heads back on a new lower end rebuild. Part of it is, as a re
builder , he would not do it because there would always be the finger
pointing if there was a warranty issue and there was a mix of old and new
rebuilds.
On my coach, when I bought it , the word was " just been rebuilt" when
prob. was just a top end job. Then 5,000 miles later I was burning 1 qt
every 150 miles and the problem was broken rings in 3 cyl. which destroyed
the block.
Might be cheaper in the long run to do the whole thing and block the oil
runs for more oil to #7 , block the manifold crossover (look for a crack in
the carb throats) , do the whole thing now while you are in there.
gene
>GMCers
>OK here is a tale of woe. The heads are off. The lower end seems fine lots
>of hone marks still in the wall nice and even. But the heads are a disaster
>area. First someone did a real cheap rebuild on this lady. The valve guides
>were knurled. The old valves were reused. There was about an 1/8 inch of
>slop at the top of each valve. Lots of buildup on the intake valves. Stem
>height wrong on two exhaust valves. Going to replace aluminum rocker
>bridges with steel ones. Going to SS valves. Roller rockers too.
>Thats where I am going.
>Take Care
>Arch
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
With the new Edelbrock manifold they send you blocks to fill the
crossover ports under the carb. This allows the air under the carb to be
preheated. In the instructions you must drill a 1/4 inch hole in each
block to allow air to move. With the Ed. Man. you have to change over to
an electric choke. If you are using the new Ed. performer manifold that
is. To you Arch. Darren
> -----Original Message-----
> From: Gcbr
> To: gmcmotorhome
> Date: Friday, October 08, 1999 6:12 PM
> Subject: Re: GMC: We are in
> >In a message dated 10/8/99 6:56:44 PM Central Daylight Time,
> Going to block off the crossovers on the manifold.
> Arch,
> I hope I don't start something here but I am curious. Why do you want to
> block the crossovers on the manifold and how will you do it? Is it to try
> to make it run cooler or??
> Bob Schoner
> Still looking for the perfect GMC
Darren Paget
76 Experimental
Another Fab Day
paget
http://www.TZEplus.com
- -----Original Message-----
To: gmcmotorhome
Arch,
Bob Schoner
