Wanted to bring up a subject: Water leaks!
Anyone who has watched the pressure test I use agrees that many leaks show
up that you would never think of and show some you though were OK. Even
with finding the se leaks there is never a guaranty that these are the only
ones there are and knowing them is only half the battle, now you have to
seal them.
I have had several instances recently that I feel compelled to talk about
this.
Because of the construction of our body, there are several flex joints
required. When you have different materials make up a skin, they will
react differently to the environment and flex differently as well.
These joints present a real challenge, gobbing them with gooey stuff does
not solve the problem. Lopping on more only makes a mess! You have to
understand the root of the problem and solve it. If the leak is caused by
lateral or sheer movement, you need to apply a product that will adhere to
the 2 nearby surfaces and shield the area that has to move and keep water
out. If the problem is adhesion of panels, a stronger adhesive on another
way to hold the panels together must be found.
You cannot expect one product or approach to seal all leaks and you cannot
expect guaranteed results every time.
Finding & sealing leaks is a real pain in the rear. It is especially
frustrating when you try the best you can and you still find leaks. It
makes you feel pretty useless, you did the work but the trouble did not go
away. It takes hours of testing, sealing & re testing and still leaks will
sometimes persist! If I charged for all the hours we take in looking for
leaks, the bill would be astronomical. I could not stay in business
sealing leaks alone, it always seems to be one of those loosing deals!
Those of you who have tight coaches, count your blessings. Those of you
that are in the hole here with me, take hart in knowing you are not alone!
There is no magic liquid but there are many people out there looking and
maybe someday a cure will be found.
Jim Bounds/Co-op Motor Works Orlando www.gmccoop.com
seal them.
this.
