Water heaters? Suburban, Atwood, American Standard, Pot onthe Stove
ronald b. kazi
523
How does the engine heat hook up. Is there a heat exchanger in the engine
compartment or does coolant flow to a heat exchanger in the water heater? Is it
hard to drain for winter storage? Does the shop manual show the system?
Ron and Julie
73 Painted Desert
> > To install the gas type water requires a major
> > modification and relocation to get it in. Some GMC'ers have done it,
> > but your talking alot of dollars here. I just hitched up the engine
> > heating circuit that the PO had removed the hoses to the engine.
> > Provides all the hot water you need without AC power.
> Ron & John,
> I'll second that idea. Reconnecting the engine heat was one of the best
> things I ever did. We rarely ever use the electric element. Main thing to
> remember is that the hot water is almost dangerously hot (~160 - 170 F) after
> a day's driving, so be careful. Of course this means your 6 gallons goes a
> long way. I'm thinking of putting in a tempering valve to make it safer.
> As for the propane unit, I believe you'll also find that the massive
> aluminum side beam that encircles our coaches will interfere with installing
> a propane water heater, as they require a large opening to the outside.
> Those GMCs (Coachman, etc. bodies) that came with a propane water heater
> mounted it down near the floor IIRC, not under the sink. Hardly seems worth
> it unless you do a LOT of long-term boondocking.
> My .02.
> Rick Staples
> '75 Eleganza
> Louisville, CO
My trip out to the coach was fruitful. The heater does not have
fittings for engine heating. I did, however, find a nice set of needle
nosed vise grips and an 8" crescent wrench wedged between the wheel well
and the bath unit! This makes back about $14 of the $4000 I have spent
on this baby so far!
Ron and Julie
73 Painted Desert
Emery,
That sounds like one of Jim Damaere's stainless steel tanks. He builds a
"pocket" into his tanks for the heat exchanger to slide into.
Patrick
> Hi Rick -- must be that GM made another design change or else changed
> vendors. My 77 hot water heater has a "well" built into the same
> side as the water lines and the heating element. There is a loop
> that has two hose fittings that go from the engine and back. This
> slides into the "well" and provides more surface area for heating.
Thanks Emery,
Didn't realize that the slide out heat exchanger wasn't Jim's original idea.
Patrick
> In a message dated 3/20/00 9:39:38 AM Mountain Standard Time,
