Guess I should also ask once we have the valve out is there any repair
replacment parts we should use.
Marlene
Marlene,
I believe that I had to remove the center of the crossmember to get my
"waste" water tank (Better Roger?) valve out. My local RV parts store
had the exact replacement parts for rebuilding the valve. I did drill
the holes (4) out to the next size and put nuts on the other side. I've
never liked threads in plastic, especially old plastic. The only other
surgery involved was drilling a small hole in the replacement slide
valve handle so I could hook it up to the GMC remote actuator.
HTH
Regards,
Steve
Marlene
Marlene,
HTH
Regards,
Steve
