O.K. Do this in order that I write them.
Cold Engine. (Overnight cold). Remove air cleaner. Observe choke plate. It
should be somewhat open. Pull the throttle back a bit and watch the choke
plate. IT SHOULD CLOSE., but not tightly. Touch the choke plate LIGHTLY
with one finger. You should feel slight tension against the finger
pressure.
Now loosen the three screws that hold the choke housing but do not
remove them. You should be able to rotate the choke housing. Watch the
choke plate as you turn the housing and stop turning the housing when the
choke plate just touches closed. Then, touch the choke plate lightly. It
should open and the spring should close it.
Now turn on the ignition, but do not try to start the engine. Watch
the choke, it should very slowly open if it is wired wrong. If it is wired
from the center post of the isolator, it will not receive voltage except
when the alternator produces current.
Start the engine. Do not pump the gas. It should start right up if
things are right. If not, let us know.
Salem, Or
> Ok, took a look at my electric choke, did not see any specific adjustment
> for winter and summer on it. Do not know about these electric chokes and how
> to set them. I see little tick marks much like the timing marks on the
> balancer. The are cast into the metal canister. But I don't see any
> adjustment
> tick marks on the cap end cover. So not sure how these get adjusted. I
> guess I'll try to search the net on how the sdjustment works, maybe I have a
> less expensive unit on there?
