very high idle... bad distributor... engine
ek_lektro
170
OK, thanks for the recommendations; I will investigate over the next few days.
(And sure hope its not the timing chain… although i guess this could be handled when doing the water pump, soon)
The Eleganza would also have this hot start problem at times, even with a brand new timing chain, brand new battery
So for this Birchhaven, we’re hoping for either slight timing adjustment, retarding it a bit, like Jim K suggested,
or maybe the heat shield issue….which is pretty interesting… and makes sense, having headers and all…
OK, Thanks again, and have a great weekend!
> Time it to start cold and no hot start. The problem went away after I
> replaced the timing chain
My suggestion to just retard a bit is based on the fact that he did not
have that issue before.
On Sat, Jul 27, 2019 at 11:39 AM Ek Lektro via Gmclist <
> days.
http://www.appliedgmc.com
Update: I had a chance to do a hot highway drive today, and fortunately the slight distributor adjustment seems to have
fixed the hot start issue. I say “seems to have fixed” the issue, because the hot highway in Los Angeles today
never got over 45 MPH... the whole hour and a half journey. But i‘d imagine the engine was hot enough for the test (?)
and i have a feeling we’ve got the problem licked, thanks!
Ran pretty excellent overall. Idle was normal at traffic lights.
Learned a lot in the process (distributor refurbishing, tune-up, etc)
and if the problem comes back, i’ll definitely try the heat shield
thanks again!
Greg / SolarSonic / LosAngeles
