Valve adjustment
Keith V
3,582
376
83
Yes, valve adjustment. Right or wrong my engine has adjustable rockers. Ive just replaced the lifters due to a bad one and went through the rocker adjustment procedure.
Being paranoid is there anyway to know if anything is off far enough to be a problem ?
Being a newbie is it worth pulling the valve covers and readjusting them while its running?
Or am i more likely to make it worse?
Keith,
If the lifters (lash adjusters) came with a static set procedure, then that should be as good anything. The range of authority of the devices is
actually pretty wide and all you need to do is be in that range. Yes, there will changes with thermal situation and wear, but that should not out
range the lash adjustment capability of those.
So, the chances are that you will not make things better while trying to do a hot reset.
Besides, you don't have the little clips to keep them from oiling the seats (again).
There is a reason why engine builders don't like to do a hot valve reset.
Good to hear it is going together.
Thanks Matt,
I did get a set of oil clips and got impatient, you know me..., so i did the pass side, it looked pretty good.
So the efi is in and calibrated, probably ready for a tuning run as soon as i figure out how to mount an air filter
Sent: Saturday, May 1, 2021 4:04:53 PM
Subject: [GMCnet] Re: Valve adjustment
Keith,
Keith,
The jeep/ Chrysler factory plastic manifold off the TB is about perfect.
Then you can duct it to wherever you put the air filter. I put mine behind
the DS headlamp assy.
Sully
Bellevue wa
> Thanks Matt,
> From: Matt Colie
> To: gmclist
> be a problem ?
> while its running?
> Keith,
> do a hot reset.
> seats (again).
> Matt
Did you try 3/4 turn after the point where it just stops ticking? Repeat 15 times. Racer guys might only go 1/2 turn past quite so high RPM pumpup
effect is minimized, but that’s not us.
John Lebetski
Woodstock, IL
I talked to Dick Patterson, he said 1/2 turn.
But the real question is how far off is too far and holds the valve open?
Not enough and it ticks, but too far??
Sent: Sunday, May 2, 2021 10:02:31 AM
John Lebetski
Woodstock, IL
Kieth,
One of the reasons for hydraulic lash adjusters is that they have a huge sense of humor..... When they are working right.
If you are doing the set even warm, the exhaust stems are so hot that there is not much thermal expansion left for them. And, don't even worry about
the intakes, they don't change enough to be an issue at all.
The thing that is important if you are doing a cold set is that you are setting the at TDC for that cylinder. Some one is bound to tell you that you
only need to set the crank in two positions... Set #1 TDC and then you can set #5I #7E #4I #9M (just seeing if you were paying attention....)
Really - That is a recipe for a mistake. The nolo contendre for best way to set or inspect lash is this...
Write the firing order in two rows
1 8 4 3
6 5 7 2 For a 455
Now roll the crank until #1 is in cross-over (Exhaust is closing and Intake is opening). Now you know the #6 should be on the dwell of the cam and
you can set both those valves. This is the way we always did it in the contract labs that I ran. Why this way? Because it is absolutely certain
that the valves you are working on are the right two. Unless you only work on one specific engine family, it is confusing and this is a sure way
though that confusion.
Side Joke: I did once own a Honda 350-4 (loved that bike). In the manual, under adjusting the valve lash it said,"Position the crankshaft so all the
valves are closed." My guess is that someone copied this from the 2 cylinder manual.
When you change stuff like camshafts, lifters, rocker arms, valves, PUSH
RODS, etc. Then all bets are off. Oldsmobiles did NOT COME FROM THE FACTORY
WITH ADJUSTABLE VALVE TRAINS. So, everything from valve lift, how far the
valve stems extend into the heads after a machine shop finishes grinding
the seats, valve faces, and stems, push rod length, lifter plunger travel
range, thread pitch on the valve adjusters, ALL CAN, AND DO INDEED, affect
preload. What a can of worms you have created for yourself.
Salem, Oregon
> Kieth,
> about
> you
> 1 8 4 3
> 6 5 7 2 For a 455
> and
> all the
> cylinder manual.
> Matt
> GMCES
Set n forget. Loosen till it ticks, tighten till the tick just stops, add 1/2 to 3/4 turn and you're good to fo. Like Matt says, there's a lot of
tolerance in the lifters. No worms here, just one more step.
--johnny
Braselton, Ga.
Depending upon the thread pitch of the valve adjusting fastener, and the
particular hydraulic lifter involved, that procedure may vary a bit. I
never did use my ears as a means of determining how much clearance is
involved. BUT, "most hydraulic lifter internal plungers have about .080" of
total travel. Somewhere about 1/2 way through that range will usually work.
Do the math on your setup, and set them accordingly.
Salem, Oregon
On Sun, May 9, 2021, 5:12 AM Johnny Bridges via Gmclist <
> --johnny
> Braselton, Ga.
> in hell
