Hello
Not sure anyone can help me but here it goes, I need to drain and dispose of both the main and reserve fuel that is 6 years old, I filled my tanks with fresh gas and added fuel conditioner before I put the unit into covered storage, I ran the RV 3 years ago and it started right up and ran fine for about 15 minutes. I was thinking of draining the tanks using the generator gas line unitil the tanks were empty which I understand will still have some fuel left in the tanks.
I am planning on running the engine temporariy using a boat style portable gas tank that holds 6 gallons and has a return line as well as a supply line.
My Plan is to disconnect the main fuel line to the fure pump but will I damage the fuel pump if I run the engine with no gas line attached?
I plan to drain the tanks using a electric fuel pump at the generator gas line into several gas storage containers to dispose of the old gas,
Has anyone drained their tanks by this method and then addded fresh gas to the old? What was the experience...
Also on the carb I have been told to put some injector cleaner down the middle of the carb to remove any possible gum that may have developed, My thought was to do this as well as in the external fuel tank I plan to use to run the engine initially.
Your information is much appreciated and Thank you for you help!
Stewart
Stewart
