> Jerry/Jack,
And read here
http://bdub.net/gmcmotorhome.info/onan.htm
> Thanks for your input and experience. I read through Jerry’s presentation
> and agree the conversion from UScarburation appears to be the way to go
> here. I thought the presentation was very detailed and easy to follow.
> The only addition I might make to the slides is a switch wiring diagram for
> dummies like me who are better following visual instructions. Jack, did
> you also install a second regulator in the propane compartment like Jerry?
> Neil (Elvis)
> 1977 Kingsley 26’ 403 engine, mostly stock with a zip-dee awning and
> ragusa step
> Calgary, Alberta, Canada
> > On Jun 27, 2017, at 10:21 AM, Jack Christensen
> > I'm not sure why one would want to do a comparison between suppliers at
> this point. Jerry Work designed a propane conversion kit that you can order
> > from USCarbueration with a single part number providing all the major
> parts you'll need. I ordered and installed the 3/8 inch hose version which
> > provided adequate propane to power two air conditioners. I don't think
> you need to spend the extra $$ for the 1/2 inch hose kit. Combined with
> Gary
> > Bovee's Pertronix ignition upgrade kit my Onan works better than ever.
> > Here's the link to Jerryi's presentation.
http://gmcws.org/blog/?p=4335
> > Jack Christensen - K6ROW,
> > '76 Glenbrook/Clasco - "The Silver Bullet",
> > Sebastopol, CA
Alternator Protection Cable
