two ways to get that ugly box off the roof
hermann beeck
70
Jim
This is just what some of us are looking for, would you please continue. =
This is high quality GMCnet content.
Thank you
- -----Original Message-----
Sent: Wed, 12 Apr 2000 22:59:02 EDT
To: gmcmotorhome
Subject: GMC: two ways to get that ugly box off the roof
Its not hard to build the roof air conditionair in side . on my 23ft=
I=20
simply set it in the space where the generator was. cold air ducted thru=20
under bed into hall way hot air supply return taken thru=20
grill near ceiling did not have to remove freon . that must have been 20=
=20
years ago beleive it or not but you can hardly here it run. =
=20
The second way I did one on a 26ft was to split the unit installing the=
=20
evaperator in an overhead cabinet with a squirrel cage blower behind ,a=
nd=20
the condencer on a angle next to the generator also with squirrel cage=20
blowing hot air out thru the floor . it worked too good the temperture dr=
op=20
thru the evaperator was 22 degrees and could blow your hat off ! I insta=
lled=20
too large a squirrel cage blower ---- .to do the job this way cost more=
had=20
to install extra lines and refill the freon. Im beginning to think Im=20
taking up to much space on this page sorry I will stop now. Jim =20
Anstett =20
______________________________________________________________________
Get Visto.com! Private groups, event calendars, email, and much more. =20
Visto.com. Life on the Dot.
Check it out @ http://www.visto.com/info
Jim
You were very impressed with the ceramic paper. Do you still recommend
this for heat insulation and noise reduction??
gene
>Jim
>Thank you
>From: JKAnstett
>To: gmcmotorhome
> Its not hard to build the roof air conditionair in side . on my 23ft I
>evaperator in an overhead cabinet with a squirrel cage blower behind ,and
>blowing hot air out thru the floor . it worked too good the temperture drop
installed
had
>Anstett
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
Where did you locate the evaporator cabinet?
>,and
>blowing hot air out thru the floor . ...
This is more along the lines of what I am thinking of doing. Where did you=
=20
get the blowers? Did you fabricate your own enclosures for the evaporator &=
=20
condenser? Where did you purchase the tubing and fittings etc for the freon=
=20
lines? Did you have any problems with the blower kicking up road dirt and=20
plugging up the condenser coils?
>.to do the job this way cost more had
I know this is going to cost more than just replacing the rooftop A/C but I=
=20
really like the idea of cleaning up the roof lines and getting the weight=20
of the A/C off of the roof and down lower.
I am also thinking that it would be nice to find a compressor that mounts=20
horizontally or is low profile enough to fit between the frame rails under=
=20
the floor. I just don't know where to look for parts & pieces to cooling=20
systems. Are you aware of anyone selling this stuff on-line?
I do like the idea of disassembling an existing air conditioner for the=20
major parts. At least that way I know it is all matched properly. And used=
=20
air conditioners are reasonably cheap and easy to find. I just wish I could=
=20
find one with a compressor that is low profile enough to fit under the=
floor.
Not at all. There are a number of us who have been thinking about ways to=20
get rid of our rooftop A/C units. Its very interesting to hear how you=20
actually did it.
Dave
Ann Arbor, MI.
73 Sequoia (26'/455/HEI/EFI/160=B0/3.42)
Can anybody come up with some pictures on this modification?
Would the condenser portion fit in the propane compartment if one goes to=
the smaller propane tank? Any thoughts?
Sent: Thu, 13 Apr 2000 09:44:00 -0400
To: gmcmotorhome
Subject: Re: GMC: two ways to get that ugly box off the roof
> The second way I did one on a 26ft was to split the unit installing =
the
>,and
This is more along the lines of what I am thinking of doing. Where did yo=
u=20
get the blowers? Did you fabricate your own enclosures for the evaporator=
&=20
condenser? Where did you purchase the tubing and fittings etc for the fre=
on=20
=20
I know this is going to cost more than just replacing the rooftop A/C but=
I=20
=20
=20
horizontally or is low profile enough to fit between the frame rails unde=
r=20
major parts. At least that way I know it is all matched properly. And use=
d=20
air conditioners are reasonably cheap and easy to find. I just wish I cou=
ld=20
find one with a compressor that is low profile enough to fit under the fl=
oor.
=20
actually did it.
Dave
Ann Arbor, MI.
