Two ideas for our GMCs
jerry work
1,108
Having now lived for close to a year with this wonderful Prevost Country Co=
ach Motorhome there are two things I would implement if we ever have anothe=
r GMC. The first is the generator sits on four small air bags that g=
reatly reduce both vibration and noise transmission. The bags sit between =
the generator mounts and the coach chassis. They are not very expensive an=
d apparently readily available. They would be easy to plumb in either by T=
off one of the compressor/air tank outlets with check valve, or by adding =
another inexpensive 12vdc compressor just for that task. The air volume is=
quite low so even a small displacement compressor would work well. Plumb =
in an air pressure regulator so you can dial in the desired air pressure. =
Wire the compressor through a relay powered off the positive post on the ge=
n coil. That way the compressor would come on only when the gen is running=
and only if the air pressure regulator called for air. Most of the time i=
t would only run for a few minutes at initial gen start and then shut off o=
nce the air bags were inflated. One could also power a 120vac small compre=
ssor (think small trim nail gun compressor) off of the 120vac output from t=
he generator with the same result. The second idea taken from the Prev=
ost also involves air. The Prevost uses small air bellows to tension the b=
elts powering the side mounted engine cooling fan. With a simple to make b=
racket and a pulley to push on the belts, it looks like one of these could =
easily tension the alternator and/or AC belts. With the air off the belts =
would be slack enough to replace by hand with no tools. With air tensionin=
g, belt squeak and stretch would automatically be compensated and replacing=
a broken belt would become an easy no-tool five minute job. The ones Prev=
ost use cost less than $50. Jerry Jerry Work The Dovetail Joint=
Fine furniture designed & hand crafted in the 1907 former Masonic Temp=
le building in historic Kerby, OR http://jerrywork.com
Hmmm... excellent ideas. Especially the belt tension-er.
Thanks Jerry
Patti & Jerry Burt
73 Gmc 26' Canyon Lands -
77 Palm Beach
Members: FMCA - GMCMI - GMCWS - Pacific Cruisers - 49ers
Pneumatic tensioners would require air pressure prior to start-up. Not a big deal, but a required discipline to adopt to avoid throwing a belt.
Les Burt
Montreal
'75 Eleganza 26'
> Thanks Jerry
> Patti & Jerry Burt
> 77 Palm Beach
Air tensioners do work for Prevost but they're used on low RPM motors vs gas motors that fast idle at near diesel governed speeds. If you've ever seen
the belts flailing away before air tensions them you'd swear they'd be pitched. I'd think a simple spring loaded tensioner could be incorporated with
little effort. Of course it would need more tension than the typical serpentine tensioner but I'd suspect it should be quite doable. KISS still rings
true IMHO. Hal
1977 Royale 101348,
1975 Eleganza II, 101230,
Rio Rancho, NM
A pretension spring would take care of the slack at starting on a gasoline engine. I had to fab up a bracket on my uncle's 350 Olds diesel to put a
tensioner on the back side of the alternator belt because the power pulse of the engine would throw the belt off at certain rpms. The unsupported
distance in the belt allowed the resonance wave to attain almost 3 inches peak to peak no matter how tight the belt was. It solved the problem but
looked homemade.
Got any pics of those air powered tensioners?
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
There are a couple of diff
erent types employed. One style is simply a small air billows/bag. Another looks like a typical air cylinder. Some of the configurations simply move a
chive/pulley against the belts others move an assembly which may have either a compressor or auxiliary alternator mounted. Nothing too high tech for
sure. Hal
1977 Royale 101348,
Rio Rancho, NM
