Transmission oil Temp
david l greenberg
8,798
1
Lanier,
>> Is the temp always (or nearly always) at 190 or over coming out of
>the
>> tranny?
>> Heinz,
>> Once it warms up, it hangs just on the left edge of the 190 mark and
>I'd
>have
>> to do some seious hill-climbing to get much over that.
>> Lanier
>That sounds excellent.
>That means it normally leaves the tranny at 180/190 and the thermostat
>in
>line with the tranny cooler will help me keep it there.
>Thanks again
>Heinz
190 out of the torque converter sounds right as my oil temp in the pan
runs around 130-140 and I have told by experts that there will be a 50
degree diff between the two.
David Lee Greenberg F22009
GMC Motorhome Registry
200 MacFarlane Drive PH4
Delray Beach, FL 33483-6829
Lanier,
Do you have the stock setup or have you added a supplemental cooler in order to
keep your transmission fluid temps from climbing above 190?
Richard
> Lanier,
> >the
> >> tranny?
> >> Heinz,
> >I'd
> >have
> >> Lanier
> >in
> >Thanks again
> >Heinz
