Hey Rick, I like the sound of this.
I don't want to give up my 3.07 ratio as it is perfect for flat land
running. Besides, when they get around to having a Western Rally at the
salt flats, I want to go through the traps 100+ in mine.
Few would argue about the benefits of lower first, second and reverse gear
ratios.
With a 3.07 final gear and the transmission modified as you mention:
First gear would be equal having a 3.40 final gear
Second gear equals a 3.26 final gear
High remains at 3.07
Reverse gear equals a 3.58 gear
This would be a big improvement and as you say, would provide the best of
both worlds.
Changing from 3.07 to a 3.42 ratio gives a 12% torque increase. I can
easily find that much additional torque in the engine and for fewer dollars.
It would be nice to have some statistics on final drive failures. Seems I
hear a bit about transmission failures but very little about final gears.
Lower first and second and reverse transmission ratios are interesting.
Hope you are able to find out more about this.
Cheers,
Don Miller
75 Glenbrook
Shenandoah Valley of Virginia
>Date: Thu, 5 Nov 1998 12:13:28 EST
>From: RickStapls
>Subject: GMC: TRANSMISSION gear ratios
> With all the recent discussion of final drive and transfer chain ratios,
I
>wonder if anyone has any information/experience with changing the actual
GEARS
>inside the transmission for different ratios?
> I read in a GMCMI newsletter from way back in '85 (newsletter #12,
summer
>'85) that a company in Fountain Valley, California was selling replacement
>gearsets which reduced the 1st, 2nd, and Reverse gears to lower
(numerically
>higher) ratios. Specifically, 1st gear went fro, 2.48:1 to 2.75:1, second
>went from 1.48:1 to 1.57:1, and reverse from 2.11:1 to 2.46:1. 3rd (high)
>gear, involving no gears within the transmission, remains at 1.00:1.
> I also recall seeing another reference to such a project, but I can't
>remember where. ("The first thing to go....") IIRC, they said the
replacement
>gears were straight-cut rather than helical like the originals, making them
a
>bit stronger abeit noisier.
> This sounds like the best of both worlds for those of us trying to start
>off on steep hills over 10,000 feet altitude. The lower 2nd gear would
give
>more power on long pulls, although one might not be able to hold 2nd gear
up
>to 70+ mph as you can now. The stock 3rd gear ratio would allow us to get
>across Kansas with minimum noise and fuel.
> Does anyone out there have any experience/information about such
>modifications? Does anyone know if "Art Car Performance Transmission" is
>still in business, or any other such sources? Any leads appreciated.
>TIA,
>Rick Staples,
>'75 Eleganza, Louisville, CO
ratios.
both worlds.
Cheers,
Don Miller
75 Glenbrook
>From: RickStapls
I
GEARS
summer
(numerically
replacement
a
give
up
>TIA,
>Rick Staples,
