At the cost of flushing with excess synthetic fluid it would be cheaper
to
put in a drain connection. Any comments?
Bob,
I would think that this would lead to an out of balance condition. I
have a Nova that I drag race occasionally and I had a terrible vibration
problem. The vibration went away when I installed a new trans &
converter. I took the old transmission back to the folks who do my
trannys and supply my converters. I described the problem and they
agreed to send the converter in for inspection and if it was bad, they
would tear down the trans & check for damage. Sure enough! A balance
weight had come off (small one) and that was the source of the
vibration. If that little weight can cause so much vibration, I wonder
what a pipe plug in a tapped hole would do to cause an out of balance
situation.
Arch is a pretty good source of info on syns; Arch, can syns be mixed
with dino fluids? After a change or two you'd think that the dino stuff
would pretty much be gone anyhow.
Just some thoughts.
Steve Ferguson
to
Bob,
situation.
Just some thoughts.
Steve Ferguson
