Transmission/Final Drive
bartz paul
1,225
FYI, here is some recent interesting dialogue on the Toro mailinglist about
transmission, in particular Caspro's Power Drive unit, and final drive
options.
Bruce Roe's input talks about Caspro's 6-speed transmission/switch pitch
trans and a controller he builds.
Paul Bartz
Date: Tue, 1 Jun 1999 09:40:27 -0400
Subject: [Toro] RE: Toro Digest V1 #1003
Alex:
As a GMC Motorhome owner, I can fill you in on the various final drive
ratios currently available. The Motorhome was only produced from 1973 -
1978, in just under 13,000 units, and only with the 3.07:1 ring and pinion
gears.
The "Castor" mentioned below is "Caspro". Their Power Drive unit
effectively gives the equivalent of a 3.50:1 final drive ratio. Some
Motorhome owners have installed the Toro 3.21:1 ring and pinion gears
individually and in conjunction with the Power Drive, which then gives an
effective ratio of 3.66:1.
There are several other final drive ring and pinion gear sets available now
also. Cinnabar has a 3.42:1, which I have installed. Two others are a
3.55:1 and a 3.67:1.
Except for the 3.21:1 ratio, each of the above mentioned units cost
approximately $800, exclusive of installation.
If you need sources for any of the above, I can furnish upon request.
Date: Mon, 31 May 1999 08:06:18 -0700
Subject: Re: [Toro] Pike's Peak chain sproket set for '66 Toro
Castor makes new chain drives for toro drivetrains (in GMC motorhome guise),
I believe they are 3.5 to 1 (the powerdrive unit I think they are advertised
at. Seems I remember in the cataloge a 6 speed TH 425 as well for mega$$$!
Date: Monday, May 31, 1999 12:06 AM
Anyone know anything about GM producing a special set of sprokets for the
chain drive with more teeth on one of the sprockets to alter the final drive
ratio? This was supposedly done to raise the effective drive ratio for
hill-climbing contests that showcased the then new Toronado's traction
prowess (late 1965).
What would the effective ratio have been? Where can I find out more about
this? Were the sprokets ever made available as a GM part No.?
Along the same lines, I know GM produced motorhomes based on the Toro FWD
platform. Did these use the stock final drive ratio (3.21/3.07 in '68 up)?
Or did they use a higher numerical ratio? How was this achieved? A new
ring & pinion or altered chain drive sprokets?
Date: Tue, 1 Jun 1999 10:14:39 -0500 (CDT)
Subject: [Toro] Chain
Alex, I would like to add to Pauls' info. The Caspro "Power Drive" chain
assembly uses a stock 65 tooth sprocket with a 57 tooth to achieve a 1.140:1
ratio which in effect multiplies the final drive ratio. It includes a
(otherwise unavailable) new chain, bearings, and seals, making a TH425 trans
rebuild a lot simpler. The exciting news is the unit can be ordered with
the sprockets REVERSED (I have one) to DIVIDE the final drive ratio and save
a lot of gas.
I believe Ralph Braun will be publishing an article I wrote in the Toro
newsletter giving all the possible ratios and more info.
The Caspro 6 speed TH425 is based on a switch pitch trans combined with a
special motor home version of my electronic switch pitch controller. The
trans has a long list of improvements over a stock 67 trans: better gears,
shift kit, Power Drive, reinforced torque converter, center bearing support
with case protection ring, to mention a few. Its probably overkill for a
car.
Speaking of 6 speed switch pitch, I ordered the crucial parts last week for
another batch of switch pitch electronic controllers (car version). Anyone
who is interested could let me know, and I'll mail you the details this
month/ units in July.
FYI. Continuing discussion on the subject from the Toro mailinglist.
Paul Bartz
Date: Wed, 2 Jun 1999 09:39:10 -0500 (CDT)
The stock TH425 chain ratio is 65:65, or 1:1 (Caspro Power Drive is =
65:57,
or about 1.14:1). The Power Drive (I bought one last year) includes =
the
chain support plate with all new bearings and seals, the sprockets with
shafts welded on, and a special chain. It is completely assembled to =
the
extent possible given the TH425 assembly procedure.
When rebuilding a TH425 it solves the problem of getting a new chain =
and all
those associated parts =20
The overall ratio in high is essentially the product of the chain and =
the
final drive, so for a 3.07 (43:14) final drive the overall is
(65/57)x(43/14) 3.502506. With the 1966/7 3.21 final dr its
(65/57)x(45/14) 3.665413 overall. This is great for a motorhome. =
However a
66 Toro also has a switch pitch torque converter which provides 25% =
more
torque multiplication. About the only time this vehicle needs a 3.21 =
is at
top speed, where there is no torque multiplication (1:1) in the =
converter.
If you don't need to drive 130 mph, a ratio in the high 2s could
considerably improve mileage.
The Power Drive can be ordered with the sprockets REVERSED so
(57/65)x(45/14) 2.8187. I will be using this setup in my 79 with a =
2.73
(41/15) for 2.40:1 overall. This same ratio on my rear drive Delta =
(stock
403) provides 0-60 in 7.5 sec and 91 mph =BC mi speed, so I am not =
concerned
about loss of performance. The electronic switch pitch controller =
fully
utilizes the extra 25% converter torque multiplication to compensate =
for the
tall gears in intermediate situations
