Transmission & Final drive pans
vic marks
220
Ron & Gina wrote: Hi Vic, So the Ragusa and Caspro Tranny pan are the same
pan? Is the final
the same also? Do you use the sealer or gaskets for both? thanks for any
info.
Ron&Gina: Yes, the Caspro products are made by Ragusa. I assume that Caspro
buys in bulk from Ragusa. I used the sealer for both. If you buy from
Caspro, he may add a transmission filter with it (or is that with the shift
kit? - which is also a very good buy from him - it is the Transco kit but
with add-ons and excellent directions) or you can just buy one from him on
the same order.
Vic
Vancouver BC
75 transmode
Thanks for info Vic, I thought they were two different manufactures. Was
looking into the shift kit, but for now my tranny's doing good, Just want to
still lower temps alittle more. Alot of sources say my tranny temps are fine
for this area. So still thinking about it. Might get the final cover for
now.
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave, AZ. 103degs. in the shade and slightly overcast
To:
Cc:
Sent: Monday, September 20, 1999 8:12 AM
Subject: GMC: Transmission & Final drive pans
same
> pan? Is the final
> info.
Caspro
shift
> the same order.
> Vic
> Vancouver BC
> 75 transmode
