As promised yesterday, I dug out the GMCMM "library" and looked for the
transmission article. It wasn't easy to find because the section I
recalled was in an article titled "Hey Mister, Your Motorhome Is On
Fire!!!" (8/97).
According to this article, transmission oil overflow may be the number
one cause of fire in GMC's. When you drive the coach hard(accelerator
pedal more than halfway down), the trans pressure regulating valve moves
toward the bottom of its travel. When it reaches the bottom, it cuts
off flow to the trans cooler and torque converter. In auto
applications, this is usually a temporary situation, but in motorhomes,
if you don't drive carefully, it can be an extended condition. The lack
of cooling causes the fluid to expand, and if the trans is full, fluid
may actually spew out the vent and filler neck. The author recommends
keeping fluid level at the "ADD" mark and driving carefully to avoid
this.
So, it's not so much a transmission problem as it is a driving problem.
Many of us(I'm guilty too) push our coaches too hard, thinking "since
they'll go that fast, why not?" I'm not sure if there is a "fix" for
this or not. I'm sure the THM400 trans used in truck app's must deal
with this somehow.
Patrick
Patrick Flowers
Mailto
atri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
Fire!!!" (8/97).
this.
with this somehow.
Patrick
Patrick Flowers
Mailto
