Transmission cooler line leaks at transmission
emerystora
14,608
2
1
Bob Dunahugh one posted to this list that you can use copper washers at the transmission to help seal the lines. He got an assortment of the washers at Harbor Freight for about $8.00.
I used his idea for the lines on my power steering pump. They really help where you have a steed to steel connection. When tighten in they form the cone shape of the fitting.
Emery Stora
It must be a Reverced Flair washer. Flat will not work.
On Sun, Sep 13, 2020 at 2:25 PM Emery Stora via Gmclist <
> Emery Stora
http://www.gmcrvparts.com
Not so, Jim. If the copper is soft (if it comes hard, hit with a torch
flame), it will deform to match the flare. But, that's not my way of
working in an "emergency":
http://www.gmcmhphotos.com/photos/g4452-flare-fitting-repair-with-copper-seal.html
On Sun, Sep 13, 2020 at 6:30 PM Jim Kanomata via Gmclist <
> help
> the
> > Emery Stora
> Jim Kanomata
> jimk
> 1-800-752-7502
