Trans temps & Monteagle
homebase1
476
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
I've towed with both a Dolly and 4-wheels down. I've found that there
is just too much slop and play in the dolly system; too many
moving pieces. My suggestion is 4-down. Stability is never a
problem and there are no restrictions to your travelling speed.
Oh, if that's a 914-6, they are the only car that can never be towed
under any circumstances! I suggest you immediately sign the title
over to me and I'll be right there to take the useless old thing off
your hands :-)................any chance you believe that?
Mike Beaton..................' 77 Kingsley
Nova Scotia....cold today still no snow!
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx
> > I plan on using a 'Car Dolly'. It is the 2 wheeled device (190
> > lbs)that allows you to tow any vehicle. I am going to use it to tow a 1970
> > Porsche 914 (1985 lbs) for a total dead weight of 2170 lbs with no
> > additional brakes. Anyone using this setup??
> I pull a live-axle dolly carrying a replica of a 1929 Mercedes SSK Roadster -
> VW rear engine/drive. Hardly know it's back there, and when I lost that front
> wheel last month I didn' t even unload the car to unhook the dolly from
> JImiSue and hook up to my pickup to pull home. Very little tongue weight - the
> dolly axle carries the weight of the front end and the car carries its own
> rear. BUT, that live axle is a real bitch if you have to back up. I plan to
> modify it to be able to lock the axle if need be. The advantage of the live
> axle is in the tracking - you can make a turn with very little swerve.
> Lanier
It seems that all the talk is about toad being hooked up with 4 wheels
down. I plan on using a 'Car Dolly'. It is the 2 wheeled device (190
>Roger
>I have no problems with braking on Monteagle. I also
>occasionally tow a Suzuki Sidekick at 2100-2200 lbs.
>My tow car offers NO brake assist, just dead weight.
>UPHILL
>I have a 1978 Eleganza with the original 403. It has
>never been rebuilt with 70,000 miles. If I can maintain
>60-65 mph I can climb in third gear. Unfortunately I have
>only been able to do that once as truck usually slow me down.
>Once I fall below 60 I loose momentum and when I get
>to 45 I shift to 2nd. I can easily hold 45-50 in 2nd.
>We also travel VERY heavy. From either direction we hit
>Monteagle with 3/4 fuel, always 3/4 to Full on water & LP,
>and we are fully packed. We carry a lot of audio and video
>equipment. I have never weight (scarred to) but would assume
>we are well over 12,500 in the coach. I run on "E" GoodYear
>tires.
>If I am towing I have to use 2nd and maintain 45 mph.
>DOWNHILL
>I use 2nd gear and hold 45 mph using occasional taps
>on the brakes. Towing makes very little difference
>on the downside. My temps all drop on the downhill
>side.
>We make the trip 5 or 6 times a year.
>Mike F
>>> Mike,
>>> I'm interested, how is it going down the South bound side of Monteagle?
>>> Braking problems, etc?
>>> Roger
>>> 7? ????
Roger
UPHILL
tires.
DOWNHILL
side.
Mike F
>> Mike,
>> Roger
>> 7? ????
