Towd MPG penalty
richshoop
198
Using a 2001 Jeep Wrangler as a towd, what could I reasonably expect for a decrease in MPG?
----- Original Message -----
To: "gmclist"
Sent: Sunday, June 18, 2017 4:28:21 PM
Subject: Re: [GMCnet] Larger Engine Oil Filter
It think it's like this. The big block and small block take a different recommended filter. Then ,there is also a longer version of each of those for
HD service.
John Lebetski
Woodstock, IL
If your running a standard ratio you can notice 3 mpg decrease
Should you have 3.70 you'll have only 1. mpg decreases
I get that. From our customers
> decrease in MPG?
> From: "John R. Lebetski"
> To: "gmclist"
> for
> HD service.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
http://www.appliedgmc.com
8 to 10 mpg
Depending on if you tow
> a
> > decrease in MPG?
> > To: "gmclist"
> > for
> > HD service.
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
> Jim Kanomata
> jimk
> 1-800-752-7502
Alternator Protection Cable
I got 10.2 MPG pulling Linda's 5000lbs Chevy Uplander lift van. With 87 Octane ethanol gas. 78 Royale 403 stock exh, carbureted, and a 3:70 FD. GVW of 17,000lbs. Pulling a car hauler with a car on it. I got 9.8 MPG with a GVW of15,000lbs. So the Uplander seems to have better air flow behind the GMC. With the 3:70 FD. My trans temps went down, and MPG's went up about 1.7 MPG's. That was with the burned GMC. Haven't calculated this 78 Royale 403, and the 3:70 FD yet. Bob Dunahugh
