Toronado final drive
kingsley coach
2,802
Does anyone remember the final drive ratio for the 1976 Olds Toronado?
Thanks
Mike in NS
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
I do not remember but it seems there was a lower ratio for a towing package.
On Thu, Aug 29, 2019 at 1:53 PM Kingsley Coach via Gmclist <
> Thanks
> Mike in NS
> Michael Beaton
> 1977 Kingsley 26-11
> Antigonish, NS
*John Phillips*
Some had a 2.73 and others had a 3.07 (trailer towing package)
The GMC used the 3.07
Emery Stora
> Mike,
> 2.73 comes to mind.
> Bruce Hislop
> ON Canada
> 77PB, 455 Dick P. rebuilt, DynamicEFI EBL EFI & ESC.1 ton front end
> http://www.gmcmhphotos.com/photos/showphoto.php?photo=29001
> My Staff says I never listen to them, or something like that
I was led to believe it was 3.55. I have one I was planning to use. Can I just count the input and output number of rotations to confirm ratio?
That's what we used to do with rear ends, seems it would work on front ends (final drive) too? I'll be pretty disappointed if it is 3.07.
1978 GMC Royal
Eastern Pennslyvania
1968 Chevrolet C20 396 Camper Special
1969 Chevrolet C20 Camper Special
1985 Buick Electra Park Avenue
1992 Camaro 25th Anniversary Heretage Edition Black
3.55 is not a stock gmc or toronado ratio but it is an after market ratio. If you have a final drive on your bench rotate both axel flanges together
at the same time exactly 1 revolution and count how many turns the input shaft turns that is the ratio you have..just like you would check a rear
wheel drive rear end
Roy Keen
Minden,NV
76 X Glenbrook
Thanks Roy, I will do that this weekend.
1978 GMC Royal
Just count the ring gear and look on our web site chart.
If you have it on the bench , what Roy said is better as ine ca miss a
tooth.
On Thu, Aug 29, 2019 at 5:32 PM Steve Adams via Gmclist <
> 1978 GMC Royal
http://www.appliedgmc.com
Looks like I have my answer
Thank you guys!
Mike in NS
On Fri, Aug 30, 2019 at 1:55 AM Jim Kanomata via Gmclist <
> tooth.
> > 1978 GMC Royal
> Jim Kanomata
> jimk
> 1-800-752-7502
Michael Beaton
1977 Kingsley 26-11
Antigonish, NS
