Tom's puller
peter brandt
743
Mark,
Make sure the insides of your knuckles are not worn - my hub / rotor
assemblies came out (too) easy, I ended up getting reconditioned knuckles,
now the bearings are a much tighter fit in the knuckles.
Good luck,
Peter
Colorado
To:
Sent: Wednesday, June 28, 2000 9:22 PM
Subject: GMC: Tom's puller
> Hey Gang:
> Pulled both front hubs today, easy. Will post photos tomorrow after I
put
> them back on. I was going to use my porta power and a short cylinder but
the
> screw post worked so well I decided not to bother. I didn't have to use my
> slide hammer, I was able to yank the rotors off. I don't like the idea of
> using a slide hammer around roller bearings anyway. The bearings had fresh
> grease on them, but both outer seals were crushed. I can't imagine how the
PO
> did that. I'll be greasing them with Mobil1 High Temp Grease.
> Thanks Tom,
> Mark A
> PS No tires yet, 7 bridgestones coming next Tuesday. The newest old tire
is
> an '88. The one that split has rust on the steel belts. Photos to follow.
Mark,
Get your hubs and knuckles checked to be sure they're in toleraance. If
your hubs and bearings came out easy, I'd wager the components are worn out.
Sorry,
Patrick
> Hey Folks:
> I just reread the comparison between Tom's puller and the
> others. I've only used Tom's, but I was concerned about the
> reports of major effort required to use it. Maybe my hub
> shaft was easy, but with an eighteen inch long one inch
> wrench, a two foot long ratchet wrench, and a half inch square
> drive socket, I had the bearings off in less than two minutes.
> It was truly very easy.
> I've yet to reinstall the bearings, but taking them off
> was so easy that I'm not going to use my portapower or my
> big 20 ton press. I'll just use Tom's and judge the
> difficulty.
> Also, I'm going to see how to easily replace the inner
> seals. Hopefully a stock piece of plumbing pipe can be
> modified as a driver.
> Photos to follow.
> Happy Camping
> Mark A.
