Toe out
steven d. ferguson
874
Bill wrote: When you say
you're going to have toe-in set to +1/8 on both sides, is this toe in?
Thought I had heard tires should be toed out 1/8.
Bill,
I should have been more specific and just said +1/8 toe. It's "out",
not "in".
Steve
Hi Arch,
All I know is My 74 GMC drives straight as an arrow and
the rear tires are toed in at the tops alot. Sometimes
I think it looks like their leaning in so far the rear
axles must be bent....but it sure drives nice..no
wiggle wobble at all.
Rob Teed 74 Painted Desert
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto:owner-gmcmotorhome]On Behalf Of tom warner
> Sent: Monday, May 08, 2000 11:07 PM
> To: gmcmotorhome
> Subject: Re: GMC: Toe out
> Arch I would suggest that everyone read the data on the site I
> posted before
> getting all wound up here. Lots of variables that change these settings.
> Size of tires (you bet), pressure in tires, camber and castor
> etc.lets try again
> http://www.web-access.net/~bmassey/front_end_alignment.html
> >In a message dated 05/08/2000 8:13:11 PM Central Daylight Time,
> >> I am not convinced that the GMC should be adjusted for
> toe-out. I set mine
> >> to 1/8" toe in and it handles very well. I would suggest that
> everyone read
> >Tom and all
> >Lets see if we can put some order to all of this. I see 1/8 both sides.
> >Is this front wheels or rear? If it is 1/8 both sides on the front does
> >that mean 1/4 on the front wheels? Gosh I hope not---thats a lot of scrub
> >miles. I have a book with that number in it ----cant find it. So
> lets start
> >back at the beginning and make all posts clear as to which we are talking
> >about----front or rear.
> >Front wheels Maintenance Manual Toe out = -1/8 inch. Minus 1/8 inch?
> >What the he** is that? I bet it is toe out equals 1/8 toe out
> but the minus
> >throws me. Tom now says 1/8 toe in----is that minus 1/8 toe out. Man
> >the devil is in the details. I have not worked on this kind of
> stuff since all
> >of these front wheel contraptions came along so all I know is
> toe in. I have
> >read that these front wheel drive beasts toe out---real foreign to me.
> >Now lets move to the rear. Maintenance Manual says toe in .06 inches.
> >You have to be kidding. Then add to this some posts that say 1/16 inch
> >toe out on each side and I dont know what to believe. Why would you toe
> >out the rear? I am only asking----I dont know.
> >Camber and castor on front and rear seem real in the Manual to me.
> >If this is also wrong PLEASE someone please speak up. There must
> >be some sanity here some where. Have I done it again and stumbled into
> >another MYTH beehive? Somebody talk to me I am trying to close in
> >on some of this.
> >Take Care
> >Arch 76 GB IL
_____________________________________________
NetZero - Defenders of the Free World
Click here for FREE Internet Access and Email
http://www.netzero.net/download/index.html
Tom,
Thanks for posting that article, it does a good job at explaining Camber,
Caster & Toe.
I will have to say though, that I tend to lean toward 1/8" toe out. I
tried toe in and it made the coach feel like it was sitting on top of a
basket ball! The toe out setting seems to make the steering more natural.
I do put the Camber right on and also give her as much caster as the law
allows or at least the adjustments will afford.
I will also tell you it is pretty interesting setting the toe on a coach
with a little play in a part. You can kick the tire and wack out the toe.
I end up kicking the tires several times to find the "average" in the pay
and set the toe at that point. Of course, I recomend making sure all the
front end components are checked and report good but it seems that some
coaches have some play on the machine even after a thorough check.
Next time you're down, take some time and come by & I'll show you what I mean.
Jim Bounds
>I am not convinced that the GMC should be adjusted for toe-out. I set mine
>to 1/8" toe in and it handles very well. I would suggest that everyone read
>this excellent article.
>>Bill,
>>not "in".
>>Steve
Just a thought, may not mean anything, I have measured the ride height
sitting on my driveway a couple of times and I always come up with 3/4
inch higher on passenger side.I'm sure it has intentionally been set
this way. could this be to compensate for crown in road? or what
Bill
> In a message dated 05/08/2000 11:51:12 PM Central Daylight Time,
> > Toe-in, very slight if any, in rear, just like a normal vehicle
> non-drive
> > wheels. It works for me.
> Rick
> Thanks. Seems like we are getting somewhere.
> Take Care
> Arch
Emery, I assume it was set 3/4 in high on pass side as it it would
seem unlikely that it could get that way by chance. Not saying its
right. As for crown in road, I thought alignment was set to compensate
for this also. Average I guess. Since my steering went south when I
changed tires(size and pressure)also relay arm, I'm wondering if the
difference in tire height 8.75 versus 9.50 is enough to affect anything.
Must admit I am shying away from changing ride height. Am seriously
considering putting old tires back on to see if that changes anything.
Will try new steering box first. Always appreciate your imput and
knowledge.
Bill
> rear
> level controls depending on what is causing the lean and set it
> level
> according to the instructions in the maintenance manual. You should
> not have
> to adjust anything to the crown of the road. If you do, what road
> do you
> pick to adjust it to? This then means that it will then be
> misadjusted for
> any other road, which means most of the time.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
