> What TPMS has worked the best for our rigs? I’ve been using the Tire-Safeguard RV 6 since Nov 2015 for pressure and temperature monitoring. I
> now have a red warning light after replacing batteries and gaskets twice. No reply yet from manufacturer. What is the membership doing for this
> critical monitoring system? I also have an IR temperature reading meter for checking hubs and bearings.
> I may have to acquire a better system since technology has advanced since 2015.
> Virgil
> TZE336V100703 w/rear bath
> Lake Oswego, OR 97035
I've been running with a system from Truck System Technologies for about 10 years now and am very satisfied. It monitors both pressure and
temperature. It uses replaceable batteries. Battery replacement about every 2 years.
I upgraded to their color display 2 years ago from a monochrome display.
I have "flow through sensors" which allow me to manually check pressure which I still do. The sensors are a tight fit in Alcoa wheels but they do
fit.
TPM is something I'd never leave home without. Some say you don't need TPM if you check your pressures every day. I don't agree with that since
problems can occur after you manually check pressure.
https://tsttruck.com/
Richard
SE Michigan
www.PalmBeachGMC.com
Roller Cam 455, TBI+EBL, 3.42 FD, 4 Bag, Macerator, Lenzi (brakes, vacuum system, front end stuff), Manny Tranny, vacuum step, Tankless + OEM water
heaters.
