Tie rods
jim bounds1
2,067
David,
To my knowledge, there is no part # for that item. The are 2 sources for
tie rods- Golby & Cinnabar. The Golby units are the adjustable style , I
do not know about the Cinnabar one.
You must have a 73 coach, the adjustable drag link was only used on the
early coaches. The one piece drag link was used in all other coaches.
Personally, I would much prefer the adjustable one. It is a pleasure to
adj. the strreing wheel to straight with the adj. drag link. The drag link
got its name from having to set up the alignment machine to straighten out
the wheel on the 1 piece bone!
Giver Golby a call (1-800-872-1462) and get one of their adjustable dog
bones, they taste great.
Hope this helps,
Jim Bounds
>Can someone give me some part numbers for the tie rod ends and for the draag
>link on the GMC?
>David
Jim Bounds / Co-op Motor Works Orlando www.gmccoop.com
Tie rod ends for GMC motorhome are:
Inner: Moog K-ES-361-R, I paid $46.83
Outer: Moog K-ES-412-RL, I paid $47.45
>David,
>Hope this helps,
>Jim Bounds
>>link on the GMC?
>>David
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
I'm sorry, I was describing the drag link, not the tie rod ends! Thanks
Thomas fro seeing my error, the #'s there are correct, I do not know the
costs in that I am at home and away from my data base. Even though they
rarly go bad, you may want to replace the adjuster sleeves, I have the part
# at the shop, let me know if you need it.
Jim Bounds
>>David,
>>Hope this helps,
>>Jim Bounds
draag
>>>link on the GMC?
>>>David
>Tom & Marg Warner
>Vernon Center NY
>1976 palmbeach
