Tid Bits. How you can be distorying your good running engine
Bob Dunahugh
2,784
4
3
And you will never know it till it's TOO LATE. Your 403, or 455 came with a=
cam gear that had an aluminum gear sprocket center. That has a plastic ge=
ar around it. Most of us are concerned about the cam chain getting loose. T=
hus retarding the cam shaft timing. That WILL NOT destroy your engine. But =
when the plastic/aluminum cam gear plastic starts to break off the aluminum=
core. Next the steel chain starts chewing up the aluminum sprocket core. T=
his then can produce lots of plastic/ aluminum contamination that then rest=
ricts ( plugs up ) the oil flow of your oil filter. Then all that contamina=
tion causes the oil filter bypass valve to open. So since the oil filter c=
an't filter the oil anymore. Then this contamination starts to destroy your=
engine main/rod bearings. The replacement chain/sprocket sets are all stee=
l. So if your engine is running great. And has never been rebuilt. You ARE =
on barrowed time. PIROID. So a couple of hundred to replace the chain set.=
Or a few thousand for a complete rebuild. This well happen at some point.=
When we bought or first 78 Royale in 2003. One of the first things I did w=
as to change that chain set. Our origin cam sprocket was still fine. That 4=
03 still runs great at 154,000 miles. Simple choice. Bob Dunahugh
And what causes this?
Piroid
-----Original Message-----
Sent: Tuesday, May 1, 2018 8:21 AM
Subject: [GMCnet] Tid Bits. How you can be distorying your good running
engine
... snip ... "But when the plastic/aluminum cam gear plastic starts to break
off the aluminum core. "
I think it is caused mostly by age, fatigue, heat cycles, etc. rather than mileage, Billy
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
I have a small inspection camera. Pulling the fuel pump should get a view o=
f the came gear in that manner Bob Dunahugh. _____________________=
___________ From: Bob Dunahugh Sent: Tuesday, May 1, 2018 8:21 AM To:=
gmclist Subject: Tid Bits. How you can be distorying you=
r good running engine And you will never know it till it's TOO LATE. Y=
our 403, or 455 came with a cam gear that had an aluminum gear sprocket cen=
ter. That has a plastic gear around it. Most of us are concerned about the=
cam chain getting loose. Thus retarding the cam shaft timing. That WILL NO=
T destroy your engine. But when the plastic/aluminum cam gear plastic start=
s to break off the aluminum core. Next the steel chain starts chewing up th=
e aluminum sprocket core. This then can produce lots of plastic/ aluminum c=
ontamination that then restricts ( plugs up ) the oil flow of your oil filt=
er. Then all that contamination causes the oil filter bypass valve to open=
. So since the oil filter can't filter the oil anymore. Then this contamina=
tion starts to destroy your engine main/rod bearings. The replacement chain=
/sprocket sets are all steel. So if your engine is running great. And has n=
ever been rebuilt. You ARE on barrowed time. PIROID. So a couple of hundre=
d to replace the chain set. Or a few thousand for a complete rebuild. This=
well happen at some point. When we bought or first 78 Royale in 2003. One =
of the first things I did was to change that chain set. Our origin cam spro=
cket was still fine. That 403 still runs great at 154,000 miles. Simple ch=
oice. Bob Dunahugh
Not all of the 455/403 engines have the cylent timing set. In fact, the
agricultural engines were not factory fitted with them. That is not to say
that you will NEVER ENCOUNTER one in a GMC. 40 years is a long time, and a
whole bunch of stuff can happen in those passing years. If your engine is
fitted with them, best advise would be to remove and replace them with a
true roller set.
> of the came gear in that manner Bob Dunahugh.
> ________________________________
> From: Bob Dunahugh
> To: gmclist
> Subject: Tid Bits. How you can be distorying your good running engine
> a cam gear that had an aluminum gear sprocket center. That has a plastic
> gear around it. Most of us are concerned about the cam chain getting loose.
> Thus retarding the cam shaft timing. That WILL NOT destroy your engine. But
> This then can produce lots of plastic/ aluminum contamination that then
> restricts ( plugs up ) the oil flow of your oil filter. Then all that
> contamination causes the oil filter bypass valve to open. So since the oil
> filter can't filter the oil anymore. Then this contamination starts to
> destroy your engine main/rod bearings. The replacement chain/sprocket sets
> are all steel. So if your engine is running great. And has never been
> rebuilt. You ARE on barrowed time. PIROID. So a couple of hundred to
> replace the chain set. Or a few thousand for a complete rebuild. This well
> happen at some point. When we bought or first 78 Royale in 2003. One of the
> first things I did was to change that chain set. Our origin cam sprocket
Carl S. I agree with your reasons 100%. I've seen this from high, and low =
mileage engine that had those gears. I bought a 403 to keep around as a cor=
e. Had been rebuilt. And had that the plastic/aluminum gear installed. Ran =
well. When it was disassembled. A third of the plastic gear was gone to the=
bottom of the oil pan. Found plastic shavings embedded in the rod/main bea=
rings. Bob Dunahugh ________________________________ From: Bob =
Dunahugh Sent: Tuesday, May 1, 2018 7:13 PM To: =
gmclist Subject: RE: Tid Bits. How you can be distorying =
your good running engine I have a small inspection camera. Pulling =
the fuel pump should get a view of the came gear in that manner Bob Dunahu=
gh. ________________________________ From: Bob Dunahugh Sent: T=
uesday, May 1, 2018 8:21 AM To: gmclist Subject: Tid Bi=
ts. How you can be distorying your good running engine And you will ne=
ver know it till it's TOO LATE. Your 403, or 455 came with a cam gear that =
had an aluminum gear sprocket center. That has a plastic gear around it. M=
ost of us are concerned about the cam chain getting loose. Thus retarding t=
he cam shaft timing. That WILL NOT destroy your engine. But when the plasti=
c/aluminum cam gear plastic starts to break off the aluminum core. Next the=
steel chain starts chewing up the aluminum sprocket core. This then can pr=
oduce lots of plastic/ aluminum contamination that then restricts ( plugs u=
p ) the oil flow of your oil filter. Then all that contamination causes th=
e oil filter bypass valve to open. So since the oil filter can't filter the=
oil anymore. Then this contamination starts to destroy your engine main/ro=
d bearings. The replacement chain/sprocket sets are all steel. So if your e=
ngine is running great. And has never been rebuilt. You ARE on barrowed tim=
e. PIROID. So a couple of hundred to replace the chain set. Or a few thous=
and for a complete rebuild. This well happen at some point. When we bought=
or first 78 Royale in 2003. One of the first things I did was to change th=
at chain set. Our origin cam sprocket was still fine. That 403 still runs g=
I changed mine out @ 85,000 miles as advised on this list. The chain was
streched. Still truckin 55k miles down the road.
bdub
core. Had been rebuilt. And had that the plastic/aluminum gear installed.
Ran well. When it was disassembled. A third of the plastic gear was gone to
the bottom of the oil pan. Found plastic shavings embedded in the rod/main
bearings. Bob Dunahugh
Subject: RE: Tid Bits. How you can be distorying your good running engine
Worked on installing axels this past week and had a bad thread in the
rotating flange on final drive. Couldn't use a tap handle as the shift
linkage from the tranny was in the way. Found a nut (3/8-16) and pressed
it on (bench vice) the square end of tap and used a ratcheting socket
wrench to clean out the tread.
> bdub
> From: Bob Dunahugh
> To: gmclist
> From: Bob Dunahugh
> To: gmclist
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
