> Carl. I too try to keep in the 12,000 mile range for the trans, and FD. As your only really changing 50% of the fluid in the trans at each
> change. Oil is really CHEEP. I put a standard magnetic engine drain plug in both. If something is failing. That magnet will show me. I just tack
> weld a jam nut. On the
inside.The weld doesn't need to be an oil tight weld. I put the trans drain plug on the side. Be careful that the plug
> doesn't hit some component on the inside of the pan. Those drain plugs sure make the job a lot simpler. Bob Dunahugh
> ________________________________
> From: Bob Dunahugh
> Sent: Monday, November 12, 2018 10:02 PM
> To: gmclist
> Subject: Tid Bites. The importance of changing your final drive lube.
> If you can't say when your FD gear lube was last changed. You need to change it. I've never pulled a FD cover off. ( One's that have lacked
> changes ) That there wasn't about a 1/4 inch of a sludge type material on the bottom of the front cover. Most is made up of the heavier components
> of the original gear lube. Thus the gear lube's that are doing most of the lubricating of the gears/bearings. Isn't doing the good job that it did
> at the beginning of service. I just pulled the cover on a 73 this last weekend. The lube looked clean. But there was that 1/4 inch of a black
> gooey material. Bob Dunahugh
I have a Ragusa pan on my transmission. It has a drain plug in it and a port for a temp sensor.
I attach a strong magnet (out of a hard drive) to the drain plug and also put one on the final drive pan, as well as the engine oil filter. I always
get a small amount of metal fuzz on the area where the magnet is located.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
