Thread Chaser+ GMC for sale
Feb 6, 1999
135
I need a thread chaser or die to clean up threads on rear spindle.
Thought that would be easy but starting to look impossible. Anyone have
any Ideas or suggestions? Also, theres an old gent in this town who
has had GMC for many years and doesn't feel like can drive it anymore.
He was asking 15.500 last summer and advertised in local paper with no
results. He called me yesterday and said he would take 13.500 and would
consider offers. Its a 73 painted desert with fairley recent engine,new
tires,chrome wheels. 455,26 foot I know he has added gas water htr
frig and other things It looks to be in fairly good cond. Anyone
wanting to know more about it can contact me or call him at
(509)586-4232 ask for Dean.
Bill 76 Edgemont
Arch
I tried the file bit sitting on side of road with traffic whizzing by.
Think I did more damage than I did good I believe if I could get the spindle
in a vice where I could get close to it and turn it I might have some luck.
The threads are pretty well mashed but the nut does screw on and tighten up
Just wondering how much pressure it would hold since it only tightens to 25
ft lbs You'd think someone would make die that would fit While I've got
you on the line, I asked a brake question last week and got no reply How come
my front brakes dont work when I lose rear brakes? I'm sure I can muddle
around and figure it out, just seems I read a post on here several months ago
about same problem. A proportional valve or some such Think I'll start with
master cylinder. Nice to be retired and be on net whenever,huh. Thanks
Bill 76 Edgemont
> Bill
> I dont know how bad your thread problem is but you might try a
> thread file. It is a file with teeth that will cut the right threads
> on any diameter. The last one I got had 8 different threads on it.
> I think I got it at NAPA. It does a good job of cleaning threads
> as long as you have some good ones to use as guides.
> Take Care
> Arch
> In a message dated 8/19/99 2:25:43 PM Central Daylight Time,
Emery The way things are going this morn you'll probably get at least two
copies of this, don't know why. When wheel came off, I was able to get
bearings, seal and new spindle nut from smalltown NAPA store The thread size is
27/32 w/20 threads per inch Did buy a thread file from them and probably should
have spent more time with it than I did. Was in hurry to get off side of road
and believed that since someone cut those threads there must be a die somewhere.
Not to be.
Scattered brake parts across freeway and have about a weeks wait for parts.
Maybe something will turn up by then.
Bill 76 Edgemont
> Bill -- what is the size in threads per inch? There are some relatively
> cheap thread files that are a square metal file about 8 inches long that have
> 8 different treads on the ends. I have one but don't know it it'll work for
> you. Without going out and taking the hubcaps and hub cover off mine I don't
> know the thread size.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
Arch I was using a thread file, just didn't have good threads for guide.
Thought purpose of two compartment master cyl was to give you brakes on one
system if you lost other. As to my other new problem when I hit reply to sender
it seems to send a copy.
Bill 76 Edgemont
> Bill
> Were you using a thread file or just a file? If you can get the nut to
> tighten up I would think you should be ok. But then I am not looking
> at it.
> You remember right. There is a proportioning valve. If something goes
> wrong it will signal you. I honestly dont know if it will keep you in brakes
> when you lose the rear ones. All I know for sure is that when I redid
> my brakes the only thing I did not replace was the valve. When I was
> bleeding my rear wheels the pedal went all the way to the floor. I ordered
> a new valve from my GMC dealer but I have not put it on yet. I will bet
> that some of the old pros here can answer you better than I can.
> Take Care
> Arch
> In a message dated 8/19/99 3:05:47 PM Central Daylight Time,
> > While I've got
> > come
> > ago
> > with
> > Bill 76 Edgemont
Rick Yeah All that technical stuff is a little confusing. What I get
from it is; Check all brake surface and replace,Replace master cyl so I wont
have to worry about that being a problem and make sure to get all air out of new
HD brake fluid. As for the spindle rethreading die, none of the parts houses or
tool supply houses knew anything about it. the spindle is 27/32 20 thread and
since the threads are pretty well scuffed off I should be able to rethread w/
13/16. Does that sound logical?
Bill
> Bill,
> Think I touched on this a few months back, but briefly: A so-called
> "dual" master cylinder (like ours) has one piston attached to the pedal, and
> another floating piston further down the same bore. As you depress the
> pedal, the primary piston passes the compensating port (little hole
> connecting to the reservoir) and starts to build up pressure. Fluid is lead
> from this chamber of the cylinder via a pipe to one set of brakes. Pressure
> in this primary chamber also presses against the secondary (floating) piston,
> and IT moves down the bore, passing ITS compensating port and building
> pressure in the secondary chamber, where another pipe leads to the OTHER set
> of brakes.
> If either set of brakes (front or rear in our case) springs a leak, the
> corresponding chamber empties, and that piston "bottoms out". If it is the
> primary piston, it moves down until it physically touches the secondary
> piston, and now pressure is applied directly to the secondary piston. If it
> is the secondary chamber that empties, the secondary piston bottoms at the
> end of the cylinder bore, and pressure builds up between the two pistons in
> the primary chamber. In either case, THEORETICALLY you still have the
> remaining half of the brakes. (In fact, the DOT required manufacturers to
> install a brake warning light to remind the poor befuddled driver that a
> failure had occurred, since this system worked so well we might not notice
> the problem otherwise!)
> HOWEVER, in the real world it doesn't work that well. Usually the problem
> is brakes which are out of adjustment, have a little air trapped in lines or
> cylinders, or spongy hoses, etc. Any/all of these things cause a low pedal.
> When one of the sets of brakes fails, you lose about 2/3 of the pedal travel
> before its piston "bottoms out". If the remaining brakes are a bit
> low/spongy, then the pedal hits the floor before the remaining brakes fully
> apply. (Your case.) Sometimes pumping the pedal will bring it up enough to
> work, but the GMC is hard to pump effectively. Also, the GMC brake system
> works hard even if it's all there, so any failure is more dramatic than in
> your car.
> BTW, the warning light/proportioning valve has little or nothing to do
> with all this, except as another place to trap air bubbles, or as as a
> potential leak between front and rear systems which might circumvent the
> intended separation.
> Hope this is not too confusing, and helps a little.
> Rick Staples
> '75 Eleganza
> Louisville, CO
Rick If I can get right sized spindle die( which as far as I know may be
avail from snap on tool, w/ no dealer in this area, closest one in Id who doesnt
answer phone) I am sure I can clean up threads and install new nut( avail from
NAPA) The only problem I have with that is that there wont be enough meat on
threads to give the strength that it originally had. May have to pull off
suspension arms and have old spindle pressed out and new one installed if avail.
Personally don't see anything to press against to remove spindle but it says so
in book. Just hate to tear things up and ruin alignment if there is other way.
At least its home in garage and not on side of road.
Bill
> w/
> Bill,
> Talk about an oddball size! I hesitate to say "do it". What I would do
> is try rethreading it as described, thoroughly clean the threads with a wire
> wheel or similar, then inspect carefully. If in doubt, get it spray-welded
> and rethreaded, or replace it. It's not a real high-stress area, but it sure
> is critical!
> My .02.
> Rick Staples
> "75 Eleganza
> Louisville, CO
Bill, I've been following your plight and personally think you'd be ahead to
remove the spindle. There shouldn't be a shortage of replacements available,
since it is a rarely damaged part. I'd feel a lot more comfortable with good
original threads on something so critical to your safety.
I'm not familiar with how the spindle is held to the arm, but why can't you
press it out without removing the arm? It would likely take a little
thought, but I'd be surprised if it isn't relatively easy. I have a
bench-top press made by Blackhawk that is essentially a Porta-Power with a
frame around it. It isn't very heavy so I'd think you could stand it on edge
and slip it over the end of the arm so as to press the spindle out and back
in while the arm is still on the coach. This way you wouldn't have to fool
with the pins, etc, and you wouldn't disturb your alignment.
Where are you located? I would be more than happy to lend this to you
(haven't used it in a couple of years!) if freight is at all practical. I am
in Lubbock, Texas, about 300 miles due west of Dallas/Fort Worth. I also
have a 4-ton Porta Power kit that you're welcome to, but I doubt if it would
work for this as you'd have to figure out how to back up the arm.
One of the list members mentioned the other day that everyone should have
their home location in their signature lines...this is another good example
of why.
Let me know. I could ship it to you Monday. Or call me at 806 789 3005.
Travis...in Lubbock, Texas hometown of Buddy Holly and not much else.
- -----Original Message-----
To: gmcmotorhome
Date: Saturday, August 21, 1999 10:02 AM
Subject: Re: GMC: Thread Chaser+ GMC for sale
be
doesnt
from
meat on
off
avail.
says so
way.
>Bill
rethread
>> w/
>> Bill,
do
wire
spray-welded
sure
>> is critical!
>> My .02.
>> Rick Staples
>> "75 Eleganza
>> Louisville, CO
believe that the OTC 927 puller we use for the front wheel bearins would do
the job, or just hit it from back with a brass flat punch.
>In a message dated 8/21/99 10:56:14 AM Eastern Daylight Time,
>how much clearance is in back of the swing arm.
>Emery Stora
>77 Kingsley
>Santa Fe, NM
Emery I do have the OTC puller and hope to have the rest of the bearing
puller from Tom shortly. Tell me how the special tool fastens to the back of
the plate that the spindle bolts to. Mine has four bolts with nuts that go thru
backing plate and flange Thought
maybe there was some threads inside holes but they are smooth bore. Looking in
my parts book I don't see nuts shown on bolts. Wonder if mine have been
modified?
Bill
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
Right Emory I finally got it The difference between tapping two
holes(diagonally} and tapping diagonal holes just had me confused. Another
thing I will be getting into soon is pulling and replacing front bearings.
Always on my old fords and corvairs I would just grab a handful of grease and
work it in with my fingers. I could almost bet this is not accepted practice
for GMC. I saw A little plastic bearing packer w/ zert fitting at Sears
yesterday. Should I be looking to buy something like this? Also been keeping
my eyes open for Mobil 1 grease but none has jumped out and bit me yet.
Bill
> In a message dated 8/22/99 1:13:14 PM Eastern Daylight Time,
> Tom Warner posted earlier that it would be 7/16" >>
> Sorry Bruce. Tom Warner stated that the OTC puller would work but it was
> actually Bruce Maxwell that gave us the info on the correct thread size.
> Bill, you questioned what was meant by the "diagonal holes". There are four
> holes and you would just thread two of the holes on opposite corners so that
> when the puller bar is bolted to the back of the plate the center pusher part
> would be centered over the center of the back of the spindle.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
