The warner puller
blank
1,525
Tom,
I'm still interested when you get one that will push the hub out of the
knuckle.
Patrick
> -----Original Message-----
> From: Tom Warner [mailto:warner]
> Sent: Thursday, March 02, 2000 11:54 AM
> To: gmcmotorhome
> Subject: Re: GMC: The warner puller
> I guess the word finally got out on what a good deal my
> pullers are. In the
> last day since returning from Florida I have received 7 phone
> calls wanting
> them. Apparently someone showed one at Alburquerque and they
> compared it to
> others on the market.
> Thanks to whoever showed it. Should not be long until there
> are enough of
> them out there that the wheel bearing probems will no longer
> be a factor for
> our coaches.
Hi Tom
I showed mine to several folks at Albuquerque and they were all impressed
with it. They all got your contact information.
I also showed it to Ken Thoma and he was amazed that you could make it for
that price.
bdub
http://www.web-access.net/~bmassey/twarner.html
>I guess the word finally got out on what a good deal my pullers are. In the
>last day since returning from Florida I have received 7 phone calls wanting
>them. Apparently someone showed one at Alburquerque and they compared it to
>Thanks to whoever showed it. Should not be long until there are enough of
>them out there that the wheel bearing probems will no longer be a factor for
>our coaches.
> >I will leave the key under the mat. The 30amp hookup is ready for you but
> >bring an extension cord. Be forewarned. Skippy will christen all six
> >tires within 5 minutes of your arrival.
> >Ron and Julie
> >> and I will be in Colorado this summer to thank you in
> >> > person (that
> >> > is the goal of the restoration project). Did I mention Julie, three
> >> > unruly kids
> >> > and Skippy the Dog will be with me? (Check carefully and you might
> >> > find Dave
> >> > Greenburg in one of the overhead compartments)
> >> > Ron and Julie
> >> > 73 Painted Desert
> >> Actually, Ron, I was planning to spend the summer at your home!
> >> David Lee Greenberg
> >> The GMC Motorhome Registry
> >> Dedicated To The Classic GMC Motorhome
> >> www.gmcss.com/registry.htm
Tom,
Why not just a plate of 1/4 steel with 6 holes in it? Three to bolt onto
the knuckle, two to attach the OTC puller to and one in the center for the
center screw on the OTC. Simple and reversible for either side.
Patrick
> I think that it would be easy, and there are several ways
> that it could be done without to much expense. One way is
> to remove the axel shaft so the puller could be used with
> the small button and push it out from behind the
> knuckle.
> I am going to look at it this week and see what I can put together.
Well, I'm in favor of pulling the knuckle/hub assembly out to service
the bearings, which means the axle doesn't need to be removed. Only the
stub axle nut must be removed. The rest of the work is done on the
bench - not standing on your head in the wheel well.
Patrick
> That would work Patrick and the pattern for the holes would be the same as
> the seal retainer. however to use it the axel must be removed.
> >Tom,
Patrick Flowers
Mailto:patrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
