We also have the Limited Slip Differential option.
We have been supplying them for few years ad have proven to be a great
option.
I have had many people call me and tell me how much they like what it does
for them.
Limited Slip is just what it says, The front wheels cannot be locked up but
allowed to slip a little when turning corners. So there is a built in
slipage
On Sat, Apr 27, 2019 at 9:44 AM Bob Dunahugh via Gmclist <
> Matt said it perfectly on the FD. Not a weak part. Just the wrong part. To
> me. Jim K's 3:70 FD is a great ratio. Towing or NOT. The 3:55 to 3:21 do
> help some. I see it that. If your spending the money. Why not get the most
> benefit from that cash outlay. Want to take the most load off your trans.
> And have it run cooler? The 3:70/4:10 will do it. And the power drive does
> nothing beneficial for the trans. That's a fact. It just makes it easier to
> put more load on the trans. After installing the 3:70. Gas mileage went up
> due to running a higher intake vacuum. I'll get off my box now. ( Grin.)
> Want to keep me off my box? Don't talk about drivetrain components. Bob
> Dunahugh 78 Royale
> ________________________________
> From: Bob Dunahugh
> Sent: Saturday, April 27, 2019 1:16 AM
> To: gmclist
> Subject: The Olds 403/455 were an outstanding choice for our GMC's
> My 425 trans/3:70 have been in service since 2003. In two different 78
> Royales. I personally rebuilt it in that year. And now have 87,000 miles
> on the pair. We've gone on one trip in all those years without towing
> something. Thus my lowest GVW all that time. Comes in at 17,000 lbs.
> When I'm towing my 24 ft trailer enclosed trailer. That has a shop/Yenko in
> it. My GVW comes in at just under 25,000 lbs. And all this with a 403. I
> don't use any synthetic oil/fluid/lubes. Never let the engine oil/filter go
> more the 3,000 miles. Change trans fluid every year. FD, and power steering
> fluid every other trans fluid change. I strongly believe that changing
> oil/fluids is the key to longevity. Over the use of synthetics. Oils CHEEP.
> Not rebuilds. So if there's a GMC out there that gets REALLY loaded. I
> think that ours is at the top. I have one rule that I believe in. Never
> use more the half throttle while pulling long steep grades. And DO NOT care
> how fast I'm going. Bob Dunahugh 78-403 Royale.
> From: Bob Dunahugh
> Sent: Friday, April 26, 2019 2:14 PM
> To: gmclist
> Subject: RE: The Olds 403/455 were an outstanding choice for our GMC's
> The hardest things on any engine are. Lost's of cold starts, short
> trips, and luging with too much throttle. Our GMC's have few cold starts as
> to miles driven. Not much for short trips. And get a 3:70 final drive.
> With standard 10W-30 oil/filter changes in the range of 3000 miles.
> Plastic timing gear changed out. Howell/GM EFI helps a lot. 200,000
> shouldn't be a problem. I have the 403 that came out of our burned 78 GMC.
> Has never been apart except for the plastic cam gear replacement. Idle oil
> pressure hot is just under 30 PSI. Compression readings 140 to 145 PSI. (
> New 150 to 155 PSI.) Used a qt of oil in 2500 miles. And has 154,000 miles
> on it. And I'm looking for another GMC to put that 403 in. Our present 78
> Royale, 403, gets lots of oil changes. 3:70 FD, and a Howell/GM EFI. Bob
> Dunahugh
http://www.appliedgmc.com
