The don't-drive-it-enough blues.
LarryW
6,031
758
113
Menomonie, WI.
> But here's what happened today:
> Macerator wouldn't run. Turned the shaft with a screwdriver--that didn't
> help at first. Fried the fuse in the attempt. Finally got it to run, but it
> does not start on every throw of the switch. I can live with that, or deal
> with it in Mansfield.
> Rick "hoping it makes KenB feel a little better" Denney
> '73 X-Glacier 230 "Jaws"
> Northern Virginia
> Offlist email: rick at rickdenney dot com
Same thing happened to me. Turned out to be a bad ground where the ground wire goes to the frame. took it apart, cleaned it up, re-installed it.
Works fine! JWID
Larry
78 Royale w/500 Caddy
Menomonie, WI.
Mine was the water pump. 3rd Napa pump failure in about 10 years. I put in a Cardone Select one this time. Not quite finished. Found two other
things wrong, but I have not left home yet so there may be more.
> Hurry & get here before you break something else!
> Ken H
Ken and Richard are not the only ones to have pre-convention issues.
I tried to leave Wednesday for Mansfield, but ~15 miles out on the expressway the Tire Pressure Monitoring System (TPMS) alarm went off! Indication
was over temperature on the passenger side rear wheel. Thought is that I have a dragging brake shoe because after pulling off I could feel the brake
drum being very hot. Let it cool off and went back home.
It could also be wheel bearings. So the plan is to take it apart in a little bit today (Thursday) and hope to leave again in the morning (Friday).
So happy I now have a garage in which to work because it is raining now and I hate to do GMC mechanical work in the rain.
Also, I went to Uhaul to fill up with LP and after that, my LP Gas regulator started to hiss! I checked for overfill but that doesn't seem to be the
case, so now I need a new regulator to be sent to me in Mansfield for a field install.
Rats!!! I wanted to visit the prison today (Thursday) in Mansfield.
I am very happy that I have TPMS!
Richard
SE Michigan
www.PalmBeachGMC.com
Coop Roller Cam 455, Howell TBI + EBL, 3.42 FD, Quadra Bag, Macerator, Lenzi stuff, Manny Tranny etc.
