Does this mean that the ground in the panel in the RV be grounded to the chassis
and not to the shore plug? Does the neutral wire have to be connected to shore
power? The generator is self explanatory, as the genset can only be grounded to
the frame. What happens to the ground wire in the shore power plug?
> > The neutral and ground do not get TIED together in any residential
> > application,
> > nor in any RV installation I have ever seen. Even though, they get
> 'grounded'
> > to
> > separate bars in the breaker box and appear to be tied together, in some
> > fashion, they are not attached to the same point. Neutral and ground do
> not
> > get
> > tied to the same point.
> Daren,
> Actually, in the U.S., the neutral and ground wires (and the system
> grounding electrode) are all tied together at the main entrance box. After
> that point, they must never be interconnected again.
> The explanation I heard was that a very heavy load or short circuit could
> cause enough voltage drop through the neutral wire that said neutral wire
> could be carrying dangerous voltage at some point. Or, the neutral wire
> could fail or become disconnected, again resulting in lethal voltage on the
> neutral. For this reason, a totally separate ground path, one which normally
> carries no load, is provided back to the main entrance. (The bare/green
> wire.)
> At the motorhome, the GENERATOR neutral may be bonded to chassis ground
> IIRC, but the shore power cord neutral MUST NOT be tied to the grounding
> system, nor must the coach neutral wire be grounded whenever the shore power
> is connected.
> HTH.
> Rick Staples
> '75 Eleganza
> Louisville, CO
Darren Paget
76 Experimental
Another Fab Day
paget
> > application,
> 'grounded'
> > to
> not
> > get
> Daren,
> wire.)
> is connected.
> HTH.
> Rick Staples
> '75 Eleganza
> Louisville, CO
Darren Paget
76 Experimental
Another Fab Day
paget
