Funny I just did my NAPA TS6469 sending
unit this weekend too. Been so long
since I bought the first one I couldn't
find it! Went and got another one and
shortly the first one will show up, I'm
sure. Original had a spade lug on it.
New one had a stud that looks like a
tiny pull type knob. Had to remove my
plastic cover to get the copper
connector on the sire to slide on the
sender. Does anyone know what they call
the proper type connector for this newer
style sender? Thought the first one came
with the connector, IIRC.
Also I added a bit of Locktite's PST
(Pipe Sealant w/Teflon) to the threads
and mine works fine. Raised the readout
to not quite half way up the scale for
normal temp. Didn't even drain the
antifreeze and lost all of about a cups
worth during the swap. Wish everything
went that easy.
Nate '75GB (Ready to put some miles on
now!) Omaha
Date: Mon, 5 Jun 2000 08:25:28 EDT
Subject: GMC: Temp Sender Threads
You should use some sealant on the
threads, lubrication and seepage can be
a
problem. I've found that the best
conductive sealant is copper or aluminum
(gold or silver colored) antiseize.
went that easy.
now!) Omaha
a
