I have new circuit boards for the TellTale lights on the dash.
They mount in the original location and use LEDs instead of bulbs.
Since the old circuit was held in place by the bulbs and the connector a screw is needed to hold it together. I use a self drilling screw so it's pretty easy.
The connector is specific to using a flex circuit so it doesn't work with the new design
All lamp positions are marked so it's a simple matter to move the wires to the new connector.
The unused lamp is also populated so you can use it for whatever you want. You just need a switch to ground and it'll light up.
This is only the circuit board and lights, I'm still working on the transparency. I have prototypes but theyre not that great
Installation is simple:
1. remove old bulbs
2. remove connector
3. mount new PCB with 1 self drilling screw
4. cut and strip the wires and insert into new connector
As always they have a life time warranty ( my lifetime ).
if it fails, it I'll fix or replace it .
cost is $50, free shipping to the lower 48
Contact/Order/Info:
email at my427v8@hotmail.com
Phone or text at 763-732-3419
1. remove old bulbs
2. remove connector
Contact/Order/Info:
