Anyone have some tips for removing factory radio and adding Bluetooth FM radio with camera and retractable 7" screen?
Very easy. There are a lot of 1 DIN units with flip up screens for back up camera and touch screen. I have one that has voice and hands free telephone via bluetooth. Also allows for wiFi. It does require getting to the back of the dash, but I suppose it can be done from the front and feed the excess wires back through the opening.Anyone have some tips for removing factory radio and adding Bluetooth FM radio with camera and retractable 7" screen?
What are the colors for each RF+, RF-, LF+, LF-, RR+, RR-, LR+, LR- ON THE OLD 8 TRACK RADIO?2 things to watch. You have to cut the dash face. Bigger trim ring to cover the larger height hole that the original 8 track player fit in.
Other is speaker wire. If you intend to try to use original speaker wires, some older coach’s used a floating ground. So speakers grounded to chassis. But normally people end up with new wire and different speaker locations.
You would have to look at the wiring diagram on bdub’s site for your year/model. Pretty sure it shows on thereWhat are the colors for each RF+, RF-, LF+, LF-, RR+, RR-, LR+, LR- ON THE OLD 8 TRACK RADIO?
Sounds good. What brand/model do you have? Does it require physical backup cam lead or will it do Bluetooth for that? ThanksVery easy. There are a lot of 1 DIN units with flip up screens for back up camera and touch screen. I have one that has voice and hands free telephone via bluetooth. Also allows for wiFi. It does require getting to the back of the dash, but I suppose it can be done from the front and feed the excess wires back through the opening.
Podofo Car Stereo Single Din Radio Support Carplay Automatic Flip Out 7'' Touch Screen Android Auto Car Multimedia Player with Bluetooth FM Radio Receiver with TF/USB/AUX Rear View Camera. Hard wired.Sounds good. What brand/model do you have? Does it require physical backup cam lead or will it do Bluetooth for that? Thanks
Matt, any advice on how to run the wires to the speakers? While waiting for parts I decided to find out why my radio doesn’t work (dead) so got my dash all torn apart. Also, where do a person get the nice map light and speakers for the cockpit?Looks like a good idea Pete. I hope you read my note that you cannot use the existing speaker wires as the OE were grounded one side and no modern amplifier can accommodate that.
Is that the same one that Alex Sirum sells?Jim,
You might just call Mikes Sadlon. He makes new "Bird Cages" in fiberglass.
