Subject: Eldo's and Toro's
cbwood
101
>Ballpark. How much does Leigh's 6 wheel system cost? > Does he install or is it
>a kit?
>Ron and Julie
>73 Painted Desert
Ron...
there's info on gene's site for the Eldo type rear brakes and what you need..
The 'warning' about reinforcing the backing plate was from Rance Baxter..Gues they had some experience that dictated it.(something about folded up...) There's a different master cylinder referenced in a couple of posts back that would probably be better than the p-30, it was for the C-30's and had a little larger pump dohickey inside(Senior moment).
Also there's TSM for 'less expensive' kits that I think I'm going to use w/80 mm in front this spring..
Their number is also referenced in some of the rear disk conversion pages on the sites..
Let me know & I will give it to you.(Dont have it handy right now)
The TSM will allow the existing 'parking' brake stuff to be used plus you can get some of the parts yourself if you want.(IE caliper w/parking brakes rebuilt from NAPA, etc..approx &70?)
Seemed more like a easy, inexpensive bolt on solution.
HTH
CBWood
77 Kingsley
MWC OK
(on 'Digest' now)
Get free personalized email at http://www.switchboardmail.com
