There is a threaded insert that restores a stripped hole that works quite
well. It is called "Keensert" it uses standard drills and taps, unlike
heli-coils. Google it.
Salem, Or
78 GMC ROYALE 403
> Brian,
> Your process is certainly correct in the case of dead-ended holes. But in
> the case of the Olds' exhaust manifold bolts, as Chuck Boyd mentioned, ONLY
> the top center bolt hole is dead-ended. All the others extend all the way
> through their respective head bosses, so a standard tap is all that's
> necessary.
> Ken H.
> On Tue, Nov 1, 2016 at 8:34 PM, Brian Waddell
> > Just so you know for sure....the tap you are to use first is a tap that
> > srcews in to the hole after you take the old bolt out. Screw this tap in
> > all the way. Go in a little, out a little. in a little more, out a
> little.
> > When it bottoms, screw it out. Now measure depth of the whole. Now get a
> > new bolt of proper length taking washer or lock washer into consideration
> > .After testing take bolt out and use non permanent lock tite paste on
> the
> > bolt....Brian 77 ele
> > ________________________________
> > From: Gmclist on behalf of Terry <
> > mrbullitt>
> > Sent: November 1, 2016 9:01 AM
> > To: gmclist
> > Subject: Re: [GMCnet] Stripped out header bolt hole advice.
> > What Dennis said, and use a bottoming tap (square ended) to clean the
> > threads all the way, blow the hole clean with air, and use the longest
> bolt
> > possible or put a stud in there. Try that before jumping into the
> > operation of stepping up to the next size larger diameter bolt.
> > Terry Kelpien
> > ASE Master Technician
> > 73 Glacier 260
> > Smithfield, Va.
> > Gmclist Info Page -
list.gmcnet.org >
gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org>
list.gmcnet.org
> > To see the collection of prior postings to the list, visit the Gmclist
> > Archives. Using Gmclist: To post a message to all the list members, send
> > email ...
