stock ft wheel bearings
kingsley coach
2,801
Netters
While reading, " One ton front caliper rubbing...", it occurred to me that
I can't recall what is an acceptable amount of movement on a stock front
bearing system.
I've always assumed zero, but I've been wrong before!
Tks
Mike in NS
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail
Virus-free.
www.avast.com
Mike,
So often we mistake the bearing clearance as the reason for the movement at the wheel.
95% of movement on a stock front wheel is coming from the worn Knuckles.
The origional knuckles had a very rough inside bore finish.
After few thousand miles, those rough surfaces get knocked down and NOW you end up with a ROcking front wheel. not a bearing. Bearings need to be
checked for clearance .002-.006.
Back in 1980, people were laughing at me as I did not know about checking the bearing clearance.
They knew I was a degreed engineer, so they thought we were exposed to those things. During the 5 years they never addressed these things as it was
all about higher math equations that i never used after college.
We have our knuckles rebuilt using a SS sleeve that is pressed in with the sleeve at 80-100 degree temp cooler , then honed to a high finish that ends
up with a slight interference fit.
We have a outer seal that is superior than the ones we have been using. We call it EXTREME Front outer bearing seal.
Why do front bearings go out befor 80-100,000 miles?
It is that flimsy outer seal that with the bearing rocking in the knuckle and losing contact with the lip on the seal. Our seal will tolerate more run
out movement before the contact is lost.
You'll find it on our sight under Front Suspension.
Should anyone desire more information,contact me.
Our Assembly are warrantied for 80-100,000 miles.
This stuff I learned from great GMC owners that were top machinists and mechanics back in 1980.
Applied/GMC
mailto:jimk
http://www.appliedgmc.com
Jim...seems some thought has gone into this. On First reading, it looks
like you took Ken Toma's approach and boosted it several steps forward.
I'll have to look closer at this!
Thanks
Mike in NS
Virus-free.
www.avast.com
> Mike,
> at the wheel.
> Jim Kanomata
> Applied/GMC
> mailto:jimk
> 1-800-752-7502
Michael Beaton
1977 Kingsley 26-11
Antigonish, NS
Mike,
Ken Toma and Roland Wilber were friends, but they both used me as a go
between as they did not want to really help each.
I was in my 30's and they were in their 70's and they both taught me lot
about GMC and in turn I helped them to acquire parts for each.
Back then there were so many bad experience with front bearings as people
were not aware of clearance and the bearings were not manufactured close to
tolerance and half the time when the were pressed on the hub, there was NO
clearance at all and some were on so tight that we needed to remove the
spacer and install one .012 thinner.
Once Wes Coughlin went to Timken and addressed the problem with tolerances,
thing got better.
On Sun, Nov 5, 2017 at 10:26 AM, Kingsley Coach
> Thanks
> Mike in NS
> source=link&utm_campaign=sig-email&utm_content=webmail>
> Virus-free.
> www.avast.com
> On Sun, Nov 5, 2017 at 12:28 PM, Jim Kanomata
> > Mike,
> > at the wheel.
> was
> the
> ends
> We
> run
> > Jim Kanomata
> > Applied/GMC
> > mailto:jimk
> > 1-800-752-7502
> Michael Beaton
> 1977 Kingsley 26-11
> Antigonish, NS
