FWIW...
From a safe vantage point, I have absorbed the recent
controversy on tire pressures and now somewhat reluctantly
"crawl out from under the bed" to offer some elaboration
on a point that had left me curious.
We have all read the load capacity rating of "Load
Range E" LT tires being predicated on a MINIMUM of
80 psi--cold. I had not read anything about operation
above that minimum.
Santa Claus brought me a paperback on RV's in general
that has a chapter addressing the care and feeding of tires.
The author cites the same minimum 80 psi requirement
for cold "LT" pressures but on goes further to address
use of pressures ABOVE the stipulated minumum.
He suggests trying another 10 psi (still cold) and running
that way unless there are signs of uneven tread wear
or there is discomfort with the resulting ride. He suggests
the upside includes possible improvements in lateral stability.
If anyone is interested in more about this source, contact
me off net and I will forward more detail. Whether his
approach would have the blessing of tire manufactures
is absolutely unknown. I offer no advice based on this
reference. (No, I'm not an attorney, just another engineer.)
Meanwhile, I will retreat to my hiding place "under the bed".
John B. (tire non-expert)
75 PB, Sunol CA
above that minimum.
75 PB, Sunol CA
